Letz talk exhaust !!!!!!!
Old 02-21-09, 05:03 PM
t70 supra
t70 supra's Avatar
Default Letz talk exhaust !!!!!!!
i afew weeks ago a certian memeber put his nur specs up for show and it got me think i am going to be jz swapping it soon its time to put up or shut up.
i have been searching high and ow for a nice system to support my t61 all i have seen are hks systems . i've looked on supraforums and from what there saying the ebay ti is really good but what is ur opnion guys NO MAGNAFLOWS no a fan of them so far i picked the
HKS universal Ti
blitz nur (if i can find 1)
carbon TI
or just open DP
Old 02-21-09, 05:57 PM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
HKS universal Ti
carbon TI
or just open DP
Twin borla:
http://www.youtube.com/watch?v=F8PtFuCTfrQ
Old 02-22-09, 01:35 PM
jdmJZA70
jdmJZA70's Avatar
custom mandrel bent turbo back piping with hks carbon ti (dual)
Old 02-22-09, 05:26 PM
RedPhoenix
RedPhoenix's Avatar
I <3 Blitz... But the HKS would be baller too.
Old 02-23-09, 08:10 AM
t70 supra
t70 supra's Avatar
i got 2000.00 left to send so i might just order the hks after i get my soarer head but u hear that the 1jz down pipe bolts right up to my system now so IDK YET
Old 02-23-09, 12:48 PM
motorheaddown
motorheaddown's Avatar
4" dp/mp to dual 3" double offset straight through Vibrant Performance mufflers; numbers are in my sig.
WG piping blended back into 4" DP:
4" Y pipe to dual 3" pipes hung on OEM hangers:
3" double offset Vibrant Performance mufflers: http://vibrantperformance.com/catalo...ef1128cda905c8
Old 02-23-09, 12:59 PM
plex
1UZFE/2JZGTE
plex's Avatar
motorheaddown that's a nice setup. I like those vibrant mufflers.
OP: I'm running mandrel 3" catback to Apexi WS mufflers, I also have 3" BL DP and HKS 3" MP. Very quiet system.
Old 02-23-09, 01:14 PM
rykwebb
rykwebb's Avatar
Blitz, but I'm biased.
Old 02-23-09, 01:42 PM
ICONYQ
ICONYQ's Avatar
I like the blitz. However I do not like the big melon launchers on these cars...I like the exhaust motorhead has. Possible a larger top but keep the rolled lip.
Old 02-23-09, 03:22 PM
motorheaddown
I couldn't be happier with the exhaust. It's actually very quiet yet performs very well. Plus, dual 3" exhausts are larger than a single 4" pipe. Consequently, the piping just gets bigger as the exhaust flows out the back.
FWIW, opening the exhaust was the single biggest improvement in performance especially when I installed the T74. The motor gained almost 4 psi of base boost pressure when on the wastegate spring, and it made nearly 150 more hp from it's original custom exhaust because the turbo spooled 5 psi more at high boost (was 28 psi; now 33 psi). Basically, a restrictive exhaust will keep a turbo boost-limited because there is no pressure differential across the hot side of the turbo.
I will never again underestimate the need to get exhaust gases efficiently past the turbine. ;-)
-scott
Old 02-24-09, 07:24 PM
t70 supra
t70 supra's Avatar
between these two the a spec is 300+ shipping i looked for a sound clip but no success not feeling the burnt tip (IHAVE 2 and im sick of them)
Old 02-24-09, 07:27 PM
dis 4 duc
Registered User
dis 4 duc's Avatar
hks carbon ti !
Old 02-24-09, 07:29 PM
t70 supra
t70 supra's Avatar
HKS Titanium universal 275 free shipped
Old 02-24-09, 10:59 PM
booja
booja's Avatar
if it were me....
id get a hks ti or the replica one on ebay for 400 shipped for an mkiv supra.
or an apexi gt spec for an mkiv... thats what i have... my gt spec is has less bends than that hks ti one you posted up first
Old 02-25-09, 04:01 PM
t70 supra
t70 supra's Avatar
the ti is a 2.5" Inlet and the a spec is 3.0" Inlet
Quick Reply: Letz talk exhaust !!!!!!!
