High Pitched Whine from 0-40mph
Old 02-20-09, 12:38 PM
User1321989
User1321989's Avatar
Default High Pitched Whine from 0-40mph
Anyone ever experience a on and off high pitched whine coming from the drivers side wheel??
I kinda ruled out wheel bearing just because the sound is not consistent.
my brakes are not grinding...
i checked the dust shield too but it doesnt seem to be rubbing on anything...
the squealing is coming from stop to around 40 where it gets highest then seems to dissipate..flat roads.
only the drivers side and has only started to occur within the last week (car was down for about a month with new suspension, and yes i have double checked all of that as well)
any one ever experience anything similar??
Old 02-20-09, 01:29 PM
2jzlex
2jzlex's Avatar
Positive it's from the wheel?
Old 02-20-09, 01:30 PM
User1321989
99% sure..... i went to an empty parking lot...threw my car in gear and let it roll while i walked next to it....its only coming from that wheel...when my buddy was in the car he didnt hear anything from the passenger side at all....
Old 02-21-09, 06:41 PM
lemaylexus
lemaylexus's Avatar
Don't some brake pads have a device that makes them squeak when its time to replace them? I remember this happening on my old Chrysler Sebring. Just needed new pads.
Old 02-22-09, 10:28 PM
Spitfire86
Spitfire86's Avatar
jack the suspect wheel up and spin it! should be easier to find the culprit of the noise.
Old 02-23-09, 07:47 AM
StiCk3
StiCk3's Avatar
Yes it's called a wear indicator. A squeak and a whine are two different noises though. It might be a wheel bearing but whining is usually associated with the power steering.
Old 02-23-09, 09:25 PM
User1321989
fixed! thanks guys
Old 06-18-10, 06:50 AM
Lexus_SC4
Lexus_SC4's Avatar
What was the problem, brake pads?
Old 06-22-10, 11:03 AM
trackball
trackball's Avatar
What is the fix / resolution if it is the power steering? Just curious. My car does this high pitched purring sound at low speeds during acceleration; sounds like this could be what you're describing. I don't mind it that much -- just want to know if it is an issue that needs to be tended to, or harmless natural progression over time.
Old 06-22-10, 11:46 AM
S142jz
S142jz's Avatar
I bet it was something simply. It's just that when it's ur personal vehicel one tends to exagerat.
P Rock
Suspension and Brakes
16
09-15-18 05:34 PM
OMLooper
08-31-18 12:32 PM
vgrafx
12-26-15 02:25 PM
BearsLexus
RX - 1st Gen (1999-2003)
12
03-13-13 11:18 AM
SilverLexo
04-17-04 06:50 PM
Quick Reply: High Pitched Whine from 0-40mph
