need help with power steering leak
Old 01-30-09, 05:01 AM
UR2klose
UR2klose's Avatar
Default need help with power steering leak
there is a hose that isnt connected to anythin. ive looked and cant tell where it is suposed to go. can someone please tell me where it goes
Old 01-30-09, 05:22 AM
sliva001
sliva001's Avatar
there's your answer
Old 01-30-09, 04:50 PM
UR2klose
UR2klose's Avatar
i do not see where it goes. can someone post a pic of theirs
Old 01-31-09, 05:36 AM
UR2klose
UR2klose's Avatar
bump...
anyone???
Old 02-04-09, 10:21 AM
dallasbean
dallasbean's Avatar
I went out and looked at mine and i see that hose goes connected to the intake pipe from the maf sencor. On the pipe you will see there is a hose that is connected to that, well there is another hole facing from that to the front of the car. that is where hose goes.
Old 02-04-09, 10:31 AM
HellFish
HellFish's Avatar
that hose connects to your intake manifold. it goes from there down into a valve on the high pressure line coming from your power steering pump. that valve helps with the engine idle while youre steering at a stop. usually those valves go bad and youre sucking oil into the intake manifold causing a smoky startup. with that said, im sure youre valve is bad and the previous owner plugged it.
JWBlack63
07-25-20 04:14 AM
EazyRice1
12
02-27-16 10:59 AM
cameratoaa
SC- 1st Gen (1992-2000)
04-06-14 06:34 AM
Piratse
09-06-12 08:23 PM
itssr20
02-19-07 08:42 PM
Quick Reply: need help with power steering leak
