Sc300 BFI build & Waterpump/timing belt change
so as a few people know my water pump went out and the car is in the garage.
I ordered the water pump and timing belt today should hopefully be here saturday or sunday...
I figured why the car was down mineas well go ahead and make a BFI..
So tonight i started the work on the car and removed both headlights, Air intake box, top and middle cam cover. i have one bolt left to get the bottom cover off but its hard to get to it behind/beside the waterpump. Also removed the accessory belt....
Ill keep yall updated....
Intake chamber removed.
passenger headlight removed.
Driver Light Removed also.
It looks Disgusting inside there!!!! alot of cleaning to be done.... middle cover is now off..
yeahhh its nasty ... whoever had the car before me was a dumbass and didnt tighten down the battery and wellthats what you get....
hopefully since the stores are closed today i will make it out tomorrow and get the parts for my bfi.
good luck with the repairs
first and foremost: seeing from your pictures it looks like you have a lot of crud and debris around the distributor. its most likely the distributor o-ring. worst scenario is that the internal bushing on the distributor are bad and that is whats leaking. if its the o-ring its an easy job. if its internal to the distributor then you have to replace the whole unit. i was going to take one apart and see if its serviceable but it didnt look like it.
replace that o-ring because it is dripping oil on your alternator and it will cause it to fry. another 200 bucks for a new one.
if you are doing the timing belt make sure to thoroughly check the TB idler pulley. it has to spin smoothly with no noise. if it makes noise you should replace it. if it seizes, and i have seen that, you will have a cluster**** to deal with afterwards.
Thank you for the advice...
so your saying to make sure the TB idler pulley spins smoothly.... but how do i keep it from seizing up?
if you are tight on cash and your idler checks out to spin smoothly you should be okay. if your idler doesnt spin smoothly then you need a new one.
you really cant do anything to prevent it from seizing. if you think its not in good shape then replace it. it should not seize if its in good shape.
Under headlight and top cover templates are finished.... waiting till tomorrow to go get the materials for the final product hopefully lol....
Didnt have just one box that was big enough but dp.pepper and nilla wafers worked just fine..
