Is this My heater Control Valve
Old 12-08-08, 05:16 PM
jdub20tx
jdub20tx's Avatar
Default Is this My heater Control Valve
My heat wont work and im not sure if this is my heater control valve. If it is are the correct hoses attached because one is dangling as you can see in the picture and there is a plastic peice sitting where i believe that hose is supposed to go.
Old 12-08-08, 07:55 PM
booja
booja's Avatar
that looks like it should be on the firewall on the passenger side on top
Old 12-08-08, 08:02 PM
msc300
msc300's Avatar
yes sir thats it cause just changed mine had small leak
Old 12-08-08, 08:05 PM
Din
Din's Avatar
how much do those things cost now a days?
Old 12-08-08, 08:21 PM
jdub20tx
jdub20tx's Avatar
Thanks alot guys... ok now what part of it actually fails? and do you see that plastic piece close to the harness on top of it? What could that be? And Msc300 is yours hoses connected that same way or does mine not look right? Just asking since yours actually WORKS lol
Old 12-09-08, 06:05 AM
msc300
msc300's Avatar
really cant tell from pics but i believe all my hoses were connected ill check today and get back to you
Old 12-09-08, 05:22 PM
JspecSC3
JspecSC3's Avatar
That is the heater valve. I leaned on mine before and ended braking it real easy. I got a replacement from Aliga for real cheap. Try sending him a PM.
Old 12-09-08, 10:29 PM
CrazySC300
CrazySC300's Avatar
I gotta put my 2 cents in on this...I just recently replaced mine as well and I was lucky enough to get the entire unit for only $50...The damn Lexus stealership wanted $396 for the entire unit and the only part that needed to be replaced was the plastic valve itself ...I guess the reason why it's so expensive, is because there is an electric motor and solenoid that operates the arm that opens and closes it...Funny thing too, is that the Lexus dealerships always seem to have this part in stock, since I'm guessing that this part is very common and is known to go bad and start leaking.
americk22
SC- 1st Gen (1992-2000)
16
01-25-23 07:34 AM
BlaineyB
03-15-12 10:35 PM
americk22
12-16-10 07:45 AM
magneti
06-03-10 03:38 AM
bigdogg49
GS - 1st Gen (1993-1997)
12-02-07 06:16 PM
Quick Reply: Is this My heater Control Valve
