Need help guys sc300 is driving me insane!!!
Old 12-04-08, 08:39 PM
Higgo
Higgo's Avatar
Default Need help guys sc300 is driving me insane!!!
SO HERES MY PROBLEM,I START MY CAR IN THE MORNING EVERYTHING IS GREAT THE CAR RUNS UNBELIEVABLE WHEN ITS COLD,LOTS OF POWER,
THE PROBLEM STARTS WHEN THE CAR GETS TO NORMAL RUNNING TEMPERATURE,THEN THE CEL SHOOTS UP A KNOCK SENSOR 52 CODE,CAR LOSES POWER,BUT STILL RUNS GOOD BUT NOT AS GOOD WHEN THE CEL LIGHT WAS OFF...
HERES MY QUESTION DO YOU THINK THAT IT IS JUST THE KNOCK SENSOR?
aND THATS ALL I NEED TO REPLACE OR IS THERE OTHER ISSUES HERE
ALL SUGGESTIONS ARE APPRECIATED
CHEERS
Old 12-07-08, 07:33 AM
SHOLEXMAN
SHOLEXMAN's Avatar
First off TAKE OFF THE CAPS LOCK! Replace the sensor and see if the light comes back on. Is your car knocking at all or no? Cause if it is you have a worse problem. How many miles are on the car? High mileage it just may be the sensor. Get more info so I can help ya out.....
Old 12-07-08, 05:05 PM
StiCk3
StiCk3's Avatar
it sounds like timing might be retarding due to the knock sensor malfunctioning. Replace it, reset the ECU and see what happens.
robertog11
11-06-18 11:07 AM
sullijd
Performance
13
11-02-11 08:40 AM
Quick Reply: Need help guys sc300 is driving me insane!!!
