Heater core bypass??
Anyone know what is the best way to bypass the heater core? i know I need to bridge the IN and OUT line on the engine side to prevent any flow to the cabin ( heater core),
Just looking to see if anyone has done this, looking for details (pic's or diagram)
Thanks!
Thanks!
assuming its a sc300 havnt done it myself but doesnt seem hard. route the line on the back of the cylinder head to the line that comes out on the passanger side coolant pipe, the pipe runs off the back of the water pump and runs all the way to the back of the engine, just connect those 2
Hacked CL to become a Mod
is it the same as this? If so, your welcome...If not, try again
https://www.clublexus.com/forums/sho...ter+core+valve
https://www.clublexus.com/forums/sho...035#post966035
I have done this on my 1j. there is a hose that comes from the block towards the back of the motor really close to the firewall. and I just ran a hose from there to a hose on the back of the head, passenger side of car, against the firewall but very easy to get to. basically look at the heater valve and core and just bypass all that plumbing.
HEY yall, resurrecting this thread i found in my search for an answer to my problem, well i recently changed my radiator cap to a trd 1.3 cap cuz my stock cap blew the f up, so like i expected the weakest link in the system would take a dump shortly after due to the higher pressure, so it ended up being the heater outlet hose that runs to the top of the cylinder head, so my question is can i just cap the inlet/outlet on the motor side to bypass the heater core? or do i need to run a hose in between both to keep coolant flowing to the back of the block? any insight would be greatly appreciated,
Tantrix
01-20-17 05:41 PM
