RPMS go up when I turn the steering wheel
Old 11-17-08, 06:59 AM
Sup2jzgte
Sup2jzgte's Avatar
Default RPMS go up when I turn the steering wheel
I have no idea what is causing this or how bad it is, but I highly doubt it's normal. Last night I was at the drive up waiting in line to get my caffeine fix and I turned my steering wheel to the right with my foot on the break and the RPM's went up by almost 150. I turn the steering wheel to the left and the same thing, I put the wheels back to straight and the idle stayed at 300-500..............I have no idea what the deal is, any thoughts?
Old 11-17-08, 07:51 AM
TLDriver
TLDriver's Avatar
Umm isn't it normal on automatics?
Old 11-17-08, 07:54 AM
Sup2jzgte
Sup2jzgte's Avatar
I thought it was only a few, but not over 100 rpms
Old 11-17-08, 07:55 AM
rwdanthony
rwdanthony's Avatar
first of all your idle is pretty low. it should be at 750-900 range. thats normal. and to yoru problem, for automatics. turning the steering wheel raises the idle by around 150 rpms. just as tldriver said, so your okay bro
Old 11-17-08, 08:01 AM
Sup2jzgte
Sup2jzgte's Avatar
lol yeah I know I have been trying to figure out why my idle is so low, I have already replaced my battery, but I'm not if its my alternator or something else.
Old 11-17-08, 11:38 AM
ihiryu
ihiryu's Avatar
it's the idle up switch, because the powersteering pump is kicking over so it's normal
Old 11-17-08, 01:20 PM
1siksc
1siksc's Avatar
it's because the power steering has variable power steering which means lower rpms the more it turns so it uses vacuum pressure. Going to a SS line was one of my favorite mod
Old 11-17-08, 04:15 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
I'm not even aware of this but 100rpm is hardly noticable
Old 11-18-08, 12:23 PM
sc250tt
sc250tt's Avatar
It is meant to to do this.Just like the ac the powersteering has a idle up feature too. This is why you have vac lines on there.
Old 11-18-08, 01:16 PM
rwdanthony
rwdanthony's Avatar
may i see you ss line? and where did you put it?
Old 11-18-08, 02:22 PM
1siksc
1siksc's Avatar
Here is where i bought it and i had it on before i did the gte swap.
http://store.driftmotion.com/Static/Item1jzpshose.php
Old 11-18-08, 05:01 PM
Sup2jzgte
Sup2jzgte's Avatar
This might be a really stupid question, but what benefits are there to doing such a mod?
Old 11-18-08, 05:46 PM
1siksc
1siksc's Avatar
Well you get to eliminate a nice long vacuum line that goes from intake to variable power steering to manifold. From my experiece the vehicle turns better aswell.
Old 11-18-08, 05:55 PM
Sup2jzgte
Sup2jzgte's Avatar
HMMM I'm going to have to look into this, thanks.
Old 11-18-08, 07:40 PM
1siksc
1siksc's Avatar
no problem and for only 65 dollars... cheap well worth it mod.
PirelliRC
01-16-15 05:14 AM
donnie boy
14
01-22-09 11:17 AM
BottomsUp
12-18-06 06:48 PM
GS430X6
07-26-05 10:22 PM
Quick Reply: RPMS go up when I turn the steering wheel
