What Supra Parts fit the SC?
I'm putting a built 2JZ-GTE in to a SC400. I'm probably going to run a GT42R on it with the V160 trans.
I'm wondering what Supra items might also work on the SC. Here are the items I'm looking at getting.
-Supra Duel fuel pump kit. (not to sure if the Supra has the same style fuel pump housing)
-Greddy 3 or 4 row FMIC. (I'm wondering if the piping would come close enough to not have to do to much cutting on it to make it fit. Also does the short route piping from a Supra also work for the SC? I ask because the front ends look similar in length and am hoping to not have to make IC pipes.)
-I've read that that supra rotors and calipers will be a direct bolt on to the SC. Does that also apply to the rear breaks as well? Do I need to replace the master cylinder along with the brakes? Proportioning valves?
-Supra Exhaust? I'm going Large single. I'm wondering if the supra downpipe and midpipe would work for the SC? What about the cat back as well? If I go 4" it will have to be something I buy as my pipe bender only bends up to 3".
Thank you for any help.
Supra LSD rearend will fit SC's as well as MKIV Springs and Struts.
There are tons of other parts as well
If your really serious about the swap and don't already have a donor car, start with a SC300 instead of a 400, the process is just a little easier, and get a USDM motor instead of JDM or be prepared to spend some extra cash to get the JDM motor up to par
I've done two GTE swaps-one in a SC300 and one is a NA supra and in the process of #3 on a SC400, and all I can say is do tons of research first.
Bentley1
SC- 1st Gen (1992-2000)
15
05-19-17 01:34 PM
