How thick is the stock tt headgasket??
Old 11-03-08, 04:23 PM
That-Guy
That-Guy's Avatar
Default How thick is the stock tt headgasket??
hey guys, i was wondering if anyone knew how thick the stock supra tt headgasket is? and headgaskets are universal between the 2jzge and 2jzgte correct? i'm wondering whether or not to get the cometic 1.3 mm or just get a stock tt headgasket if it's thinner because i don't want to lower compression too much in order to retain off boost performance.
Old 11-03-08, 04:32 PM
trancuongv
trancuongv's Avatar
stock tt headgasket is 1.3mm
Old 11-03-08, 05:38 PM
That-Guy
That-Guy's Avatar
it's the same as the cometic? then why does cometic make an hg, is the cometic better?
Old 11-03-08, 07:22 PM
5sp_jzz30
5sp_jzz30's Avatar
thicker doesnt mean better. thicker head gasket will reduce your static compression ratio as well as mess a bit with your cam timing. a thicker gasket is a cheap, ghetto remedy to reducing CR for FI use.
cometic head gaskets are made for a variety of applications in which some engines use an organic type chit gaskets. a cometic gasket is layer metal. it much stronger then a conventional gasket.
for example the 7M comes with a chit gasket. cometic makes a metal one to solve those very well known issues with that motor. arp head studs help too in that case.
suprakidxx
13
12-08-19 01:07 AM
2jzcrazy
Suspension and Brakes
04-15-14 05:14 PM
xspsi6
05-16-13 07:42 PM
ISFFUN
11-16-11 06:24 PM
PsiQo1
15
11-15-05 12:17 PM
Quick Reply: How thick is the stock tt headgasket??
