Want better low end performance, try this! It's free!
Old 10-23-12, 07:50 PM
  #211
SEIDO
SEIDO's Avatar
So have any '96+ owners done this yet?
I kinda want to, and installing a switch sounds good.
Old 10-23-12, 08:00 PM
  #212
xspsi6
xspsi6's Avatar
I think it will work for obd2 people but for sure it will throw a check engine light.
Old 10-28-12, 06:29 PM
  #213
xspsi6
xspsi6's Avatar
Here is a guy who says he used an 11.2 ohm resistor to get rid of the cel on an obd2 car which is interesting
http://www.toyotanation.com/forum/10...ode-p1765.html
Old 10-28-12, 06:33 PM
  #214
xspsi6
xspsi6's Avatar
I just did this to my 97 sc400 and although I have not taken it for a drive yet I am getting a hard code P1765 TOYOTA - Linear Shift Solenoid Circuit Fault
So I will see how it behaves shortly.
Old 10-28-12, 07:34 PM
  #215
xspsi6
xspsi6's Avatar
Ok it does seem to have better low end but I have 275's out back and they would not turn over before now if I get on the converter from a dig she will roast them most of the way through 1st gear and although I did not notice hard down shifts it does seem more alive I guess you could say, I was down there doing some work and I figured why not? Now I will put it on a switch before putting it back together.
Old 10-28-12, 08:05 PM
  #216
durps
durps's Avatar
How could I wire this to my PWR button
Old 10-28-12, 08:12 PM
  #217
MooJohn
MooJohn's Avatar
You'll notice that any WOT that results in a downshift to first will be a lot more "productive" than before. I think even a downshift from 60 mph to pass somebody is night and day difference.
It's how the car should have been from the factory.
durps - I planned to use the wire for the ECT Power dash light to trigger a relay but I decided why bother. I just left the wire cut permanently. On my OBD1 car it doesn't cause any CELs and I see no reason to ever want it back the old way.
Old 10-28-12, 08:55 PM
  #218
xspsi6
xspsi6's Avatar
Well my car has always shifted firm for some odd reason so that maybe why I did not notice any real difference when shifting but sitting on the converter from a dig gets the car out of the hole much quicker than before so it behaves like a v-8 should down low but falls on it's face up top lol
Old 10-29-12, 02:30 AM
  #219
SEIDO
SEIDO's Avatar
I shoulda been more specific haha ... "Has anyone had success with this, on a 96+ Sc300?"
Old 10-29-12, 08:18 AM
  #220
xspsi6
xspsi6's Avatar
It was a success I would say but as expected the cel came on but other than that it does exactly what it was supposed to do.
Old 10-29-12, 02:13 PM
  #221
maynanator
maynanator's Avatar
could someone explain how to do the ect power switch set-up? by explain i mean a very thorough, which wire goes where, and what panels i need to take off to find the areas to splice. thanks
Old 10-29-12, 08:00 PM
  #222
xspsi6
xspsi6's Avatar
Don't really know about that as I am just going to run a micro switch by the fuel release in the blank plate that is there.
Old 10-31-12, 03:41 AM
  #223
SEIDO
SEIDO's Avatar
LOL, yeah, but you're on an Sc400!
Old 10-31-12, 05:21 AM
  #224
Clean400
Clean400's Avatar
Has anyone done any tests on this when you give the ECU signal a 5V constant instead of cutting it?
It's my understanding that the ECU progressively raises voltage from 0-5V to enable the smooth increase in line pressure. Does having it cut automatically default the signal for line pressure to be Full line pressure? It would be interesting if someone could test this and measure the line pressure changes when gives it varying voltages between 0 and 5v.
Old 10-31-12, 09:45 AM
  #225
MooJohn
MooJohn's Avatar
The solenoid is a bleed, meaning that when it isn't energized the trans pressure is normal. Most other models of the same trans don't even have the solenoid present. With the mod the pressure isn't ever really "raised" -- it just isn't "lowered".
Triggering the solenoid lowers line pressure and causes slip, and makes a nice comfy gear change at the expense of clutch packs and overall power delivery.
Quick Reply: Want better low end performance, try this! It's free!
