Want better low end performance, try this! It's free!
Old 02-06-11, 07:27 PM
  #181
MuGGzyx
MuGGzyx's Avatar
Almost 2 years since cutting the wire. No noticeable "down side" besides a rough downshift to 1st when coming to a stop but once you get used to it it's no big deal.
Old 02-17-11, 09:46 PM
  #182
Gaza
Gaza's Avatar
I'm going to give this a shot this weekend.Thanks for the post.
Old 02-22-11, 02:30 PM
  #183
boney31
boney31's Avatar
did this put a toggle switch on an ran it to my steering wheel. works great once u retrain the ecu u will really see the diff. no codes by the way an i only turn it on an off when car is still
Old 03-20-11, 10:03 PM
  #184
STORMINSC4
STORMINSC4's Avatar
i just did the wiring for the switch and i am going to retrain ecu..what is the best method to do that.. drive like hell. with switch engaged(normal) or not? or drive like some granny like some other sites recommend.. WHY IS THIS MY ONLY UNANSWERED QUESTION ON THIS FORUM?
Old 03-20-11, 11:53 PM
  #185
llcjr
llcjr's Avatar
good information sir
Old 03-21-11, 09:18 AM
  #186
MMCtuner
MMCtuner's Avatar
STORMINSC4 Sorry but I don´t understand your question, maybe nobody answered because no one understood?
Old 03-21-11, 08:42 PM
  #187
1WILLY1
1WILLY1's Avatar
i believe his question was 'whats the best way to re train the ecu'?
drive hard until it learns or drive it soft?
Old 03-22-11, 10:08 AM
  #188
MMCtuner
MMCtuner's Avatar
Thanks *****, now I understood.
The ECU will still re-learning so if you drive hard you will have a week or so of good acceleration times and a faster car, but then if you drive it slower, the ecu will relearn again and your car will be smooth, but slower.
Old 03-23-11, 06:34 PM
  #189
1jzchris
1jzchris's Avatar
Finally done reading ALL the post..............lol. Everything seems ok. Im going to unplug that sensor tomorrow. keep you guys posted.....
Lots of great info guys......................Thanks
Old 04-11-11, 10:28 PM
  #190
CheVelleSS
CheVelleSS's Avatar
Thinking about trying this myself, My SC seems very limited in 1st and a slow shifter.
Also on the subject of wearing out the trans. If in fact all this solenoid does is bleed the pressure for smoother shifts and limited take off then it will in fact make the trans clutches last longer since they will not be slipping as much during first and during shifts. The downside would be that harder shifts and increase power to the wheels would be more abuse to the transmission hard parts, to the drivetrain parts behind the trans and engine mounts. But what performance upgrades doesnt cause more abuse to them?
Old 04-13-11, 06:11 AM
  #191
Launch1
Launch1's Avatar
Great info guys. I also have felt that the off the line performance on mine is sluggish. I'm going to disconnect the solenoid and see how it goes. Report to follow.
Old 04-17-11, 09:01 PM
  #192
sc4doubleO
sc4doubleO's Avatar
Did this for the past 3 months and it does shift firmer and faster. However first to second still slow on wide open throttle all other gears shift way faster.
Old 04-17-11, 09:52 PM
  #193
xspsi6
xspsi6's Avatar
So nobody has done this on an obd 2 car with success yet?
Old 05-02-11, 01:15 AM
  #194
Meanshyguy
Meanshyguy's Avatar
Good info, although I'm a little scared to try this since I like the comfort of my car, I guess I'm getting old, lol!
Old 05-09-11, 01:54 PM
  #195
MuGGzyx
MuGGzyx's Avatar
The down shift to first when you are slowing down takes some getting used to, but it's nut actually hurting anything. I don't really notice it anymore but I have had friends that are in to cars ride with me ask "WTF is THAT!?" when I come to a stop sometimes. For me it was well worth the effort and accelerating didn't make it less comfortable to drive.
Quick Reply: Want better low end performance, try this! It's free!
