2jzgte and 2jzge pulleys
They're the same from everything I've read. The only difference I've come across is that the VVTi motors have a different water pump pulley than the earlier models.
hmmm i also read somewhere that the sc uses a different power steering pulley than the supra. is that false? cause if the supra is also 2jzge/gte based then the pulleys have to be the same. ahh idk who to trust but im leaning towards you guys right now. just in case im talking about the p/s, a/c, fan, crank, etc, pulleys.
I just measured my aristo fan pulley and it's alittle bigger than the clutch fan pulley from my ge. I was hoping to swap over the ge pulley when i replace the hydraulic fan with a new water pump. Even though the ge pulley is alittle smaller I'm thinking the tensioner will make up for the small size difference. UNLESS the ge waterpump pulley is in fact a different size than the GTEs.
GTX580
Performance & Maintenance
11-15-16 12:40 AM
