97 SC400 No Start Need Ideas!
Old 09-05-08, 03:07 PM
Ali SC3
Ali SC3's Avatar
this sounds exactly like what my freinds corolla was doing.
it was one of those large transistor plugs in the engine bay.
makes a buzzing/clicking sound when its on its way out and once its gone its silent.
funny thing was it was the plug for the headlights which worked, but prevented the car from starting. I checked toyota ecu diagrams for the car and anything on the common ground line will do wierd stuff to the car.
cranking and everything else was healthy, i knew something fishy was going on cause the engine sounded like it was about to start everytime then just wouldnt actually start.
hope that helps.
im not even sure you can visually inspect the transistors.
the car did start fine once we simply unplugged the bad one. definately sounds electrical cause it should at least start and die or make really bad sounds if something mechanically is wrong.
Old 09-05-08, 07:39 PM
demise77
demise77's Avatar
yeah it was all removed it was painters tape. Definitly nothing fell in or otherwise it would be making a quite a ruckess.
Old 09-06-08, 04:24 AM
KC95SC400
KC95SC400's Avatar
If you have fuel.... and you have spark to all cyls..... you must have compression and or timing issue.
An engine only needs 4 things to run really. Fuel, spark, compression, and to have the three timed properlly.
KC
Old 09-06-08, 08:05 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
I would question if the timing belt was re-installed in the right position.
Old 01-09-14, 08:46 PM
ronev
ronev's Avatar
any solution to this problem?
lateralnw
12-03-18 07:23 PM
JoeGree
RX - 1st Gen (1999-2003)
15
01-28-17 06:33 AM
Tofubento
12-19-11 10:38 AM
LonnieC
Maintenance
04-16-11 06:32 PM
clean4dr
Maintenance
12-14-09 02:51 PM
Quick Reply: 97 SC400 No Start Need Ideas!
