08-31-08, 01:41 PM
1999 Lexus SC My Garage
Rising_Sun To The Rescue
Quote:
Originally Posted by Rising_Sun
Eh.... Decent start.
Tood You know Your Bat Phone Is About Too Start Ringing. I Have to do that Fuel Return Line. Did you get any information on that XSPOWER Front Mount Intercooler (FMIC) kit Supra TT
Link: http://cgi.ebay.com/ebaymotors/2JZ-G...d=p3911.c0.m14
__________________
Got BOOST ?
94 Mazda 626 Brilliant Black (PX) The Beater
03 IS300 Millennium Silver Metallic (1CO) Working Progresss
99 SC300 Imperial Jade Mica (6Q7) With 2JZGTE VVTi & W58 & Two Tone Interior Swap
http://www.youtube.com/watch?v=m6nziwq4mTA
10-11-08, 02:28 AM
DR.tweak does good work!!
Quote:
Originally Posted by TURBO819
COMPLETED
1: ARISTO 2jzgte vvti & SC300 2jzge vvti shipped to Phoenix Tuning for hybrid harness conversion
2: Removed Transmission
3: Removed Crankshaft Pulley
Parts Ordered
1: Supra Turbo Oil Return Flange
2: Turbo # 2 Oil Return Line
3: Oil Return Hose & Clamps
I am now able to order the Water Pump, Timing Belt, Cam Seals ,Front Seal ,Rear Seal. I did not think I would be able to remove the Crank Shaft Pulley Bolt. With my wife's help and a bar that I attached to the rear of the engine with the fly wheel bolts and a breaker bar with a jack handel (2ft) it came off very eazy.
Next On The List
1: Remove Sump
2: Attach Super Turbo Oil Return Flange
3: Wait For Hybrid Harness
4: Look For 2jzgte vvti ECU
08-23-08, 06:03 PM
Atleast he's not grabbing his cookie cutter and jumping on the bandwagon.
Can't wait to see how it turns out. Subscribed.
08-24-08, 12:13 AM
1999 Lexus SC
Sweet can't wait to see the finished car
__________________
under construction. tee hee.
09-01-08, 07:24 AM
1999 Lexus GS
way to go kenny! dunno how i didn't see this thread... lol
I can't wait to see this thing running.
__________________
09-02-08, 02:06 PM
what are your goals?
__________________
1988 Chevys S10 4x4 4.3-Torsion Key lift, soon to be SAS (Daily driver)
1995 SC300 [Renaissance Red, 6000k HIDs, 17 inch IS rims, BFI, Pioneer Single DIN head unit, 12 inch Alpine Type R, 600 Watt Alpine Amp, Custom center console and center glove box]
09-04-08, 04:11 PM
My Goals
Quote:
For right now I would like to use the Factory TT and get 350whp
The future I think a HYBRID TWIN TURBO set-up with 450whp and V160 transmission  If the 2jzge puts out about 182 whp. A 168whp gain with the Factory TT OR A 268whp gain with the HYBRID TWIN TURBO set-up
__________________
Got BOOST ?
09-16-08, 05:57 PM
So Far So Good
So Far
1: Installed Water Pump
2: Installed SC300 Oil pan
3: Drilled Oil Return In SC300 Oil Pan
4: Installed SC300 Engine Mount Brackets
Hybrid Harness From ARISTO / SC300 Should Be In This Week From Dr.TWEAK
__________________
Got BOOST ?
09-16-08, 06:46 PM
Nice, let us know how that harness works out. this may be a future swap for me to. or na-t
__________________
09-16-08, 10:37 PM
No Problem
I will for sure. It's taking longer than I plan for
__________________
Got BOOST ?
09-17-08, 05:41 PM
Hybrid Aristo / SC300 Harness
Dr.Tweak Hybrid Aristo / SC300 Harness is in with Transmission Simulator
__________________
Got BOOST ?
09-18-08, 12:12 AM
Whats the cost of everything for u atm?
__________________
 GTE or 1JZ
09-18-08, 03:48 PM
atm ????
Quote:
atm????? please explain? My brain is out of it today
__________________
Got BOOST ?
09-18-08, 04:02 PM
Well I don't want to add things up until I get the car running. I might not want to put any more money into this project. MY goal is to be under $5500.00
__________________
Got BOOST ?
09-18-08, 03:50 PM
atm = at the moment
__________________
1997 SC300 Silver/Black - stock - daily driver
1999 Jeep Wrangler TJ 4cyl - Red/Tan - WARN M6000, Teraflex 3in. lift, Mickey Thompson Classics, etc.
Tags
2220420010, 2jzgte, 2jzgte vvti, 89661, avn726e, ecu, hack, lines, manual conversion, pictures, prowler217, supra, swap, tt, two tone interior, vvti, waterpump  |
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
