Ewww, leftovers. :(
Old 07-30-08, 07:45 PM
OneJay
OneJay's Avatar
Default Ewww, leftovers. :(
Just curious, all you guys that did a 1JZ/2JZ swap, or went NA-T, or just did a lot of work on your engine, what kinds of leftover pieces did you have. I'm not talking about extra things you didn't use, I'm talking about things that were on the car before, and should be in the car now, but aren't. I have a couple ziplock bags of nuts and bolts from god knows where. Runs just fine though. For now.
Old 07-30-08, 07:58 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
I have an assortment of nuts and bolts that have found their way into my toolbox
Old 07-30-08, 09:39 PM
5sp_jzz30
5sp_jzz30's Avatar
none...everything i take off goes back on. the only way it doesnt make its way back is if it gets replaced or is taken off for the exact purpose of...well being taken off.
Old 07-30-08, 10:25 PM
papodotcom
papodotcom's Avatar
damn i thought i was the only one that this happened to.
Old 07-31-08, 10:09 AM
Gunnar
Gunnar's Avatar
What sucks is when you get done putting your upper intake manifold/y-plenum/throttle body back on, and you're cursing the car and you're just happy to have it done, then you notice three steel gaskets sitting on the cowl of the car still.
Old 07-31-08, 02:58 PM
sorka
sorka's Avatar
Everything is taken and placed in order of assembly with associated parts. Any bolts, nuts or screws that can be screwed back into their locations after a part is removed is done so as it is impossible to forget to put it back on or remember where it came from. In addition, I always take high resolution photos of any complicated task before and during disassembly.
Old 07-31-08, 03:56 PM
5sp_jzz30
5sp_jzz30's Avatar
my man. thats how its done. nothing is complicated if you are organized
YODAONE
07-28-16 10:15 PM
MongooseGA
03-23-14 02:10 PM
antonio356
01-23-14 06:07 PM
SC2JZ300
06-03-09 09:32 AM
flyspyder5
10-13-07 10:54 AM
Quick Reply: Ewww, leftovers. :(
