07-02-08, 07:34 AM
My Mishimoto Radiator Experience
Well after reading this thread - http://www.clublexus.com/forums/show...light=radiator - I went ahead and picked up the supra radiator for my sc300 with 1jz swap. I've used mishimoto products before and this is why I chose them to replace my hairline cracked stocker.
I don't know if it's because I have an sc300 platform, but I wasn't able to utilize the oem shroud. The radiator fits decent but is almost an 1" thicker than the stock unit which caused my shroud to hit my i/c piping. Another thing is the endtank mounts don't line up to factory so I will be fabing something up for that as well.
Probably should've went with a different company that made a radiator for an sc300. I'll have it out to day and let you know if it is sufficient in cooling without the use of the shroud.
__________________
1992 SC300 - Singled 1JZ
07-02-08, 06:14 PM
Well, the car had no cooling problems on this humid 85* day.
__________________
07-02-08, 06:18 PM
I used a koyo 2jz radiator you have to mode it, but hey you gain a super stacked radiator!
07-02-08, 07:54 PM
i used a koyo radiator on mine. the sc fan shroud doesnt fit .you have to get a gte fan shroud. Also the upper end brackets dont fit either.
07-02-08, 08:18 PM
Quote:
I made my shroud fit, i have a 400 though...
07-03-08, 05:44 AM
i just installed a mishimoto in my sc00 na-t 2 weeks ago .. it fits fine .. all you have to do is trim the battery tray slightly to acc the width of the new rad , fab up a quick l shaped bracket to mount the shroud on the pass side for drivers side lines up, trim the bottom to fit bottom rad hose and drain cocks and again fab a quick little l shaped bracket to secure the bottom shroud and as far as height , dont bend the the brackets just flip the stock rubber upside down and it raises the rad to proper height and the top mount bracket just flatten out just a tad and it will mount up top just fine
__________________
1997 sc 300 NA-T black/custom tan int,AEM TUNED by alpha
auto couture body kit ,t67 dbb .81 a/r,2.5mm boostlogic headgasket,3in boostlogic down pipe,boostlogic manifold,tial 44mm WG,r154 soarer 5sp,act stage 3 clutch, lsd 3.77 diff, tial 50mm blowoff,rc eng 750cc injectors,walbro intank,walbro inline,HKS DLI,fsm -10 fuel rail,mishimoto 3row rad,teins,daizen sways,&swiss 20x9/20x11,rotora 6piston frnt 4piston rear 355mm brakes,3in ex piping into dual magnaflow racing ex
dyno # to come
07-02-08, 08:06 PM
^You have the bend the upper brackets down a bit.
LSEGHATCH, How much did your mishimoto radiator cost you?
07-03-08, 06:33 AM
i have been running my car without a shroud for about a year now. never had an overheating issue. i used my sc300 without the shroud for Drift Days too. 4 drift events total and not a single issue...knock on wood...
most of the time you have to modify the shroud to make it fit again.
i put in a mishimoto on my friends s13 convertible a few weeks ago and it needed some minor modifications too, even though i was said to be a direct drop in.
__________________
07-05-08, 11:39 AM
I just installed a Mishimoto for the TT Supra into the Aristo 2JZ-GTE swapped SC300 I'm sorting out for my Father. I encountered the exact same problems described above - I also trimmed the battery tray and fan shroud to fit the Mishi radiator and craftily bent the radiator brackets down to fit.
I didn't have any IC piping clearance issues, but its a damn tight fit. I'm running the stock Supra TT SMIC and some creative custom piping that uses mostly stock TT Supra piping.
But I'm really not happy with the upper radiator brackets - does anyone have a better solution than bending the OE brackets?
__________________
1995 Supra SE Hardtop, USDM GTE/6-spd swap, FMIC, cams, singled, fuel, Brembo, Sparcos, Racelogic, etc etc
1987 Supra Turbo Hardtop, silver/grey, 399.2rwhp 425.2rwtq SAE (down & waiting for swap)
1992 Subaru SVX, 60-1 single turbo, FMIC, WRX 5-spd, Emanage, fuel bits, etc.
1991 LS400, leather & a/c!
07-05-08, 01:23 PM
i bent the brackets down a bit but theres still some play. I put squished a rubber hose inbetween the bracket and the radiator until i can com up with something else.
07-05-08, 02:17 PM
07-06-08, 07:31 AM
I got my radiator for $225 shipped. The Godspeeds are supposed to be just like the Mishimotos, I've never used them though.
__________________
07-06-08, 09:40 AM
i forgot to mention i got a tt radiator and the shroud didnt fit. i think i need a tt fan shroud.
07-06-08, 11:25 AM
Its weird that mine lined up properly. Probably the slight differences from the 300 to the 400?
Either way, glad its in.
__________________
IN PROGRESS...
1uz -> W58 Conversion - Blitz Nur Spec Exhaust - E46 4300K Retrofit - Griffin Emblem - SSR Professors 18"x8.5"/10.5" - Bilstein Hypercoil Coilovers - Supra TT Front Brakes
www.MySoarer.com
11-02-09, 02:10 PM
how does it flow compared to the Koyo radiators?
__________________
EFI-101 Certified
EFI-Advanced Certified
DBB PT67 turbo'd SC300 FTW
Tags
2jz, brackets, cock, drain, emblem, forum, godspeed, hawaii, mishimoto, mounting, radiator, sc300, sc400, upper, vendor, wrx  |
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
