SC400 Wont crank over by key, I need a expert!
we had a LS400 in the other day there is a connector that, if water gets into will stop contact, its right behind the manifold by the firewall 4 pin connector white cover push it and see it will start or if start will click
Former Sponsor - Cancelled
Forgot to ask, is there any type of aftermarket alarm in the car? if so, the ****ty starter kill relay they put in some can cause problems (if there is a starter kill relay present, you can take it out quickly and reconnect the 2 ends of the starer wire back together to bypass this)
Scott,
Have you read this article? http://www.lextreme.com/dx-starter.html Perhaps you should double check your ground wires. BTW, I have 1997 SC400 Diagrams. PM me what u need.
Super Moderator
Location: Sideways on the Yellow Brick Road! < Thats KS!
Scott,
Yep David, That was the first informitive artical I found. Which ground wires are we talking about?
Scott,
Trace this diagram
See if any of the compounants are not working properly. It is very common for the Lexus to have loose wires under the relays in the fuse box. Have a friend get in your car and turn the key and you put your ear close to the starter relays and listen for the click sound. If it doesnt click, the relay is either not getting juice or its is broken. I have few relays are home if you want them. Since your car is manual now, double check the Neutral switch. It might be loose.
Trace this diagram
Super Moderator
Thanks David for the diagram, It may be a help. What I am trying to figure out is what role the neutral switch plays.
I origanally jumpered the two pins on my harness to get the car to start and to this point that had been working. Where is the actual NSS located on our cars? I am still wondering about it.
Also trying to understand the starter relay. I have a very good understanding how realays work, In fact that is how I got the car started to get it home. I applied power by jumping pins A4 too B8 and it started.
The relay is good but I get no power at B10 or B7, does the Theft deterent sytem actually power the relay coli and the switch supply ground or vise-versa?
Where is the theft Deterent system located?
Scott, if you've got no power to B10 after you turn the key then it sounds like you have an issue with the neutral safety switch. The anti theft ecu supplies the ground to start relay. I had to get my starter firing recently and the checklist is should help out greatly.
Eric
Eric
You should trace B10 and back.
Neutral Switch
Theft Deterrent
Ignition Main Relay
Check for loose connection where relays are plug in. Try this, get into the car and put key on to power. While try to LOCK and UNLOCK the door switch feel times. That would reset the theft deterrent.
Neutral Switch
Theft Deterrent
Ignition Main Relay
Super Moderator
Thanks for all your help guys! I got it fixed and suddenly feel really stupid! There was a fuse up in the drivers side kick panel that was blown. I checked everything under the hood, didnt realize I had a fuse for the starter relay inside the car.
Still, I wonder why it blew? Chances are it will do it again. Fuses blow because there is a problem, I have a feeling this is not solved.
If you wanted to, you could hook up an amp meter across the fuse terminals, with the fuse removed, to see what kind of power is going across the fuse when you start the car. If the amps are spiking high compared to the fuse rating then you may have a problem somewhere. Too much resistence somewhere, if something was shorted to ground the fuse would have blown again right away.
KC
