Dual walbro fuel pumps?
Old 06-26-08, 05:19 PM
  #31
ConSynX
ConSynX's Avatar
how are you guys providing the electirical feed for the second pump?
I know i can run a relay off the trigger for the 12V's from the Fuel Pump ECU to have it kick on only when there is a load, and that i feed straight from the battery, but I can't figure out how to get past the lid to the tank. I have ports for the fuel coming out there, but the passes for the positive and negative and coated. i'm sceptical about removing the coating with how much crap I have in the back seat, and how i am stripped in the back.
Old 06-26-08, 06:11 PM
  #32
c0wboy
Banned
c0wboy's Avatar
Hi ConSynX,
The second 12V lead in installed through the pass through. The ground point is at the strap itself. The strap is a wide honkin' piece of aluminum so it'll conduct just fine. The strap is affixed to the points at the tank.
Thanks!
Eric
Old 06-26-08, 07:53 PM
  #33
ConSynX
ConSynX's Avatar
i think i get what you are saying.
what i am worried about is the pass through for two main reasons:
Aren't they generally rated by amperage? if so, can the oem pass through handle the current drawn by two walbros?
How do i get the new wire attached to the pass through that is covered in the substance to separate it from the ground?
Old 06-26-08, 09:21 PM
  #34
c0wboy
Banned
c0wboy's Avatar
The pass through is a proper bulkhead conector and it just allows the line to literally pass through and connect to the relays. It's a stainless assembly with a viton rubber ring on the interior to hold the line in place. There's no soldering required, just pull the wires through and land into the relays.
Thanks!!
Eric
Old 06-27-08, 09:35 AM
  #35
ConSynX
ConSynX's Avatar
are we talking about the same sc300 hanger? lol.
i'll have to take another look at the oem hanger, don't remember a gromet.
Thanks for your help through this so far.
Old 06-27-08, 12:05 PM
  #36
c0wboy
Banned
c0wboy's Avatar
Right, not the OEM hanger, I was refering to the billet hanger. Sorry for the mix up man.
Eric
Old 06-27-08, 02:58 PM
  #37
ConSynX
ConSynX's Avatar
ahhhh, I'm trying to figure out how to run the second lead for the oem hanger. . .
Anyone?
Old 06-29-08, 07:15 AM
  #38
ConSynX
ConSynX's Avatar
Default re:
bumperooski. . .
after googling, it seems like the ideal is to get a sealed bulkhead meant for fuel use...
where to get one?
and also, i found post of someone that was using something like it, but it still required epoxy sealing???
Old 07-14-08, 02:38 PM
  #39
ConSynX
ConSynX's Avatar
Bumping because it would be nice to have dependable electrical feeds for both pumps.
Old 07-14-08, 02:44 PM
  #40
LexusFTW
LexusFTW's Avatar
Im sure c0wboy could help you out with getting something that will seal. I know he has helped another member on here.
Old 07-15-08, 06:17 PM
  #41
forcefed86
forcefed86's Avatar
Did you use the MVP hangar? How did you install it?
Just a suggestion but I rigged my second walbro to a pressure switch. The second pump only comes on at anything over 10psi. NO need to have them both going all the time
Originally Posted by Blk97SC300
Why would I run into the same problem with 2 walbro fuel pumps? Explain please...
I installed the 2nd walbro fuel pump last night- it fits like a glove
It fits perfectly in the "bucket" looking thing in the fuel tank. I did run a 4 gauge wire from the battery to a relay, and wired the relay in order to get max voltage.
I also did this: https://www.clublexus.com/forums/sho...ghlight=walbro
I haven't tuned it at high boost yet, but the car does run a bit richer. My fuel pressure went up from ~40psi to about 55psi, so I had to turn it back down. These little suckers whine... sounds kinda cool IMO haha.
I'll post up some pics. I didn't use a new hanger- I just clamped the fuel pump to the first walbro, and replaced the hard line thats normally connected to the hanger with a 5/16" fuel line and T'd it off. I have some pics that I'll upload to this thread once I find my camera.
I'll probably tune it at high boost sometime next week.. hopefully I don't run outta fuel. Whatta u guys think of the setup now? I have 1 relay for both pumps, and I also did that other 12v mod (link above).
Allen
97-SC300
49
02-22-20 01:23 AM
nivekwb88
IS - 1st Gen (2001-2005)
05-29-15 07:10 PM
Biggu
03-01-11 07:56 PM
RedPhoenix
04-21-07 04:59 PM
MyScRuNmIa
Maintenance
08-22-05 09:27 PM
Quick Reply: Dual walbro fuel pumps?
