Need Help picking out an ECU
Old 06-08-14, 06:59 PM
Aswilley
Aswilley's Avatar
Default Need Help picking out an ECU
I will be doing the TT ECU MOD from Ali SC3 write up but am confused as to what ecu I will need.
I am currently in a 97 SC300 Auto going N/A-T
I know that I need a USDM GTE ECU to keep my OBDII intact... but does it matter if it is from and auto or a manual? and What year range GTE ECU (96-98 non-vvti twin turbo)
If I do need an USDM GTE A/T ECU will my Stock GE trans still be controlled corectly or will i have to do a similar mod like listed in the write up for the OBDI cars.
Last question is, do I still need a TT MAP sensor with the GTE ECU if I am keeping the Stock Dizzy.. I have 550 injectors, DS62 Ignitor, and a TT MAF.. so the last part of my quest is to figure out WHAT ECU DO I NEED???
sorry for the repetitive post in different areas just trying to get as many eyes and opinions as possible
Old 06-08-14, 08:57 PM
ZeRoSe7en
ZeRoSe7en's Avatar
Honestly I would skip all that work and headache, standalone or a good piggyback will work better. Ive used AEM V2 piggyback and it worked great, even just street tuned. It was on a 99 NA-T.
Old 06-09-14, 06:45 AM
Aswilley
Aswilley's Avatar
I would love the AEM v2 but cost went up to $2k .. And I'm not sure what model to get it for. Would i still get a AEM for a GE even though I'm going to turbo it?
Even a used one for a GE is around $1300 and I have everything except the TT ECU and a Map...
Just more cost effective at this point to finish the mod
Old 06-09-14, 08:03 AM
ZeRoSe7en
ZeRoSe7en's Avatar
Im sorry, I didnt have the V2, its actually the AEM Fuel/Ingnition Control # 30-1070. Its a really good piggyback that works with your stock ecu. Its only like $360 new. I figure thats a lot cheaper than a new engine block.
Old 06-09-14, 12:10 PM
Aswilley
Aswilley's Avatar
I was wondering if there was a piggy back like an SAFC or a FIC that would work but a lot of people on here say that the stock GE ECU doesnt handle boost well even with a piggy back.. So that's why I decided to do the TT ECU Mod
Old 06-09-14, 12:56 PM
Ali SC3
Ali SC3's Avatar
you could do a whole FI/C setup with the works it might end up working decent cause it intercepts all the outputs of the stock ecu, not like a safc which just plays with the maf or map signal, these are very different.
People generally only do this to keep the stock ecu and be emission friendly on an odb2 car though.
you could get an aem v1 which would do most of what you want plug and play just will need tuning, really you can't skip the tuning part but not a bad option with no emissions.
you can also use a gte ecu, but odb2 ecu's with the tt ecu mod have been having mixed results.
since you don't have to deal with emissions, just run an odb1 JDM gte ecu, that way you get a map sensor, can run larger inejctors with a simple piggyback, and not have to worry about any maf stuff.
I only basically recommend the odb2 tt ecu mod for those who are odb2 and have to be emission friendly, although the emission friendly part turned out to be the easiest part, and they run and drive but are just not boosting well. hopefully those members will figure it out and remove the doubt, but for know I only know the JDM odb1 works great, and honestly its the best one to use since its map sensor based.
so I would recommend going with the JDM odb1 gte ecu, or go aem ems v1 or v2 and get some tuning, both will work well. the gte ecu will be more factory reliable, but with the aem you can squeeze out a little more power from the tuning. just depends what you are looking for.
Old 06-09-14, 01:01 PM
Tabaka
Tabaka's Avatar
JDM GTE ECU OBD1 is what you want.
I have one, PM me.
1a1mk4
04-06-18 10:27 AM
2jzforlife
18
01-28-13 10:57 AM
jwin
27
12-12-12 12:56 PM
jwin
06-30-12 11:21 AM
Shadowen
SC- 1st Gen (1992-2000)
12-29-09 08:06 PM
Quick Reply: Need Help picking out an ECU
