running hot need a lil help
Old 05-29-08, 08:09 PM
desol11
desol11's Avatar
Default running hot need a lil help
wasup guyz need a lil help. i have a 94 sc 300, and the problem i am having is that when it is hot outside and i am at a stop light my car starts to run hot, but when i drive it starts to cool. when it is night time or cool outside it does not run hot. i had a cel code 71 and 41 which is temp sensor and egr. the question i have is does the coolant sensor work as a switch for the fan or do you think my fan clutch is bad or do you think it is the thermostat. thanks i just want to get a lil feed back before i start to drop money. also another ques where can i get a book for this car
Old 05-30-08, 12:15 PM
desol11
desol11's Avatar
anybody??"""
Old 05-30-08, 12:39 PM
hershsc400
hershsc400's Avatar
well its never a bad idea to upgrade ur thermostat, its a cheap fix/upgrade... but when it comes to cooling issues it can be anything. it maybe the coolant temp sensor or even as little as a radiator hose that has a small leak/crack which would cause the car to over heat not by dripping coolant btu by letting it evaporate (*sp)
Calliope
03-16-17 06:04 AM
SCB12345
11-03-15 06:44 AM
pearl95lex
04-05-12 08:14 AM
LS4Lalonde
08-03-11 02:29 PM
Och
73
11-03-09 06:58 PM
Quick Reply: running hot need a lil help
