Club Lexus FI V8 list
Old 05-21-08, 09:11 PM
KC95SC400
KC95SC400's Avatar
Default Club Lexus FI V8 list
They have a list over on Lextreme and I thought it might be a good idea to start one here. I know there's a couple of us, and maybe a few not as well know. Could be a good place to start for anyone who is considering an FI setup on a UZ motor, the list seems to be growing fairly quick! I will cut and paste everyone's info to this post.
Supply some basic info.
Username:
Year:
Model:
Type of FI:
Details / Supporting mods:
Best Dyno #'s if known:
Best track time if known:
Other mods:
Plans for the near future:
I'll start..
Username: KC95SC400
Year: 95
Model: SC400
Type of FI: Supercharged
Details / Supporting mods: Vortech V-9 F-trim with 2.25 inch pulley, counter clockwise rotation bolted on using Lextreme's "fish" bracket. FMIC, 315 Supra injectors, Walboro HP fuel pump, MAFTPro running MAP for fuel management.
Transmission / rear: Accumulators shimmed, increased line pressure and no 4 solenoid disabled. 2800 rpm Dragon. Supra LSD with stock gears.
Exhaust: EK Tuning 4 into 1 headers. Dual 2.5 inch mandrel exhaust with 3 Magnaflow muffs.
Other mods: Supra TT wheels with lots of rubber installed on them. OEM Supra struts with swift springs. Replaced spare with can of fix a flat and installed battery and sub amp into spare tire well. Removed cruise control and charcol canister. Stant 170 degree thermostat. Water wetter. E-fans. EGR valve deleted, a few other things deleted, boost and AFR gauges.
Best Dyno #'s if known: 350 RWHP and 300 RWTQ at 8.4 psi.
Best track time if known: 12.85 with a crap 60ft and running heavy
Plans for the near future: Don't know yet.........open to suggestions.....
KC
Old 05-22-08, 05:05 AM
paulwd
paulwd's Avatar
Username: paulwd
Year:1991
Model:UZZ31 Soarer
Details / Supporting mods:Whipple twinscrew, set for 8lbs of boost. Walbro fuel pump, Magnafuel rising rate fuel reg, Rush large bore headers, custom 2 1/4 twin exhaust. Rebuilt trans with an MV shift kit, Celsior 4 pot brakes.
Best Dyno #'s if known:311 RWHP
Best track time if known:not yet
Other mods: Cosmetic mod-- full bare metal respray
Plans for the near future: Adaptronic piggy back and bigger injectors, and a good tune. raise the boost to about 11/12lbs.
Old 05-22-08, 09:29 AM
c0wboy
Banned
c0wboy's Avatar
Username: c0wboy
Year:1997
Model:Supra
Type of FI: Twin Turbo
Engine:
2uzfe 4.7L iron block
XXXXXXXXXXXXXXXXXXXX cams
XXXXXXXXXXXXXXXXXXXX valve springs
XXXXXXXXXXXXXXXXXXXX 1mm oversized valves
XXXXXXXXXXXXXXXXXXXX stage 2 head port package
XXXXXXXXXXXXXXXXXXXX intake manifold
Q45 TB
Cometic head gaksets
ARP head studs
Ross pistons
Pauter Rods
ARP main studs
XXXXXXXXXXXXXXXXXXXX chrome 3" catch can
Turbo:
XXXXXXXXXXXXXXXXXXXX turbo kit featuring Borg Warner extended tip turbos. All custom work.
TIAL 38mm wastegates
dual in/dual out intercooler
Trans
Sp400 stage 2
3.76 rear ratio
Pro Torque 3400 stall hybrid converter
Suspension
TRD big assed sway bars
TEIN CS coilevers
Brakes
Rotora 6 pot fr, 4 pot rear 14" kit
Goodriche black brake lines
ABS delete
Fuel
XXXXXXXXXXXXXXXXXXXXXX Triple Denso billet hanger
Earls Pro Lite black fuel line
Earl fuel filters
Aeromotive polished FPR
XXXXXXXXXXXXXXXXXXXXXX fuel rail kit
Lucas 750cc high Z injectors
ECU
Link G3 Plus stanalone ECU
custom plug n' play harness
Interior
Katzkin medium red interior w/ black inserts. 100% coverage on every panel front to back
Leatherseats.com 1500pile MKIV carpet
Sparco Milano seats
Momo steering wheel
Momo hub
Momo shift ****
Momo e-brake handle
Momo boots
Pivot Tach, water temp, oil temp, boost, and oil presure
AFX wideband
Pivot push start
Stock iginition switch relocation
Dash painted to body color
Center window switch relocation
Center console HVAC relocation
Audio
Eclipse AVN5495 head unit
Eclipse 8365 components
Eclipse 7200 12" (x2)
Eclipse X1000 amp (x2)
Eclipse X4000 multichannel amp
Optima red top
Sirius tuner built into the dash
Ipod built into the dash
Body
Black cherry metallic paint (Jag OEM color on the Super V8)
custom one off widebody, 12" wider total
Bomex front, Blitz sides, stock rear, all heavily massaged
Shaved wing
Shaved rear wiper
Custom quilted mirror stainless hood liner
Wheels/tires
BFG KD fr, 295-35-18
BFG drag radial rear 345-30-18
Work Equip wheels, 18x11 fr, 18x13 rear -7 offset, disassembled, powdercoated, and black zinc bolts
Lighting
97/98 headlights
HID lows
turnsignal relcation to fog lamp area
97/98 tail lights
LED conversion
Chome and other accounterments
Chrome throughout, chrome everywhere, to much to list. Please see pics
Custom harness passthough
Earls black Pro Lite lines used throughout
Summit back fittings used throughout
Best Dyno #'s if known: under construction
Best track time if known: not tracking this car
Other mods: listed
Plans for the near future: Finish and show.
Old 05-23-08, 07:01 PM
KC95SC400
KC95SC400's Avatar
c0wboy, your the man for sure!
Where's the rest? ScottURnot? stevechumo? Twizted? SC400TT? Lextreme?
KC
Old 05-23-08, 08:17 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
Year: 97
Model: SC400
Color: Diamond Pearl white
Type of FI: Supercharged M90 Completely Flowed by MagnaPort
Supporting Mods: Stock bottom end for now, Walbro pump, Fuel upgrades and stand alone in process
Dyno #’s: This summer (will update)
Track time: This summer (will update)
Wheels: 2 sets
Street: Work Rezax II's, Lightweight 3 Piece Forged Design
Front Wheels – 20”x 9” wide with 36 offset (2 ½” lip)
Rear Wheels – 20” x 10” wide with 35 offset (3 ½” lip)
Track: CCW classics
Fronts - Skinny’s
Rears – MT ET streets 10.5 x 26 on 10” rims
Body kit: Authentic JIC Magic Body kit
Suspension: JIC FLT-TAR coilovers, Rear TT sway bar
Brakes: TT Front & Rear Calipers, IRotors slotted drilled @ plated rotors F & R, Braided brake lines, Hurst Line lock
Exhaust: S & S Headers, Custom built Dual 2 1/2" mandrel bent stainless dual Exhaust, Magnaflow hi-flow cats, X-Pipe, resonators, Mufflers & tips
Transmission: 97 Supra Getrag six speed
Shifter: C’s short shifter
Clutch: Quarter master twin disc clutch set up
Rear end: Supra TT 6 speed LSD Rear-end 3.133 ratio, Supra TT rear sub-frame assembly
Interior: Custom one off two tone interior (Black and Tan), Recaro Leather Trend seats, Matching leather custom sewn rear seat, Perforated leather 3 spoke steering wheel, Custom Black Wood interior parts, Gages mounted in custom glove box panel fabricated from Carbon fiber, Auto meter carbon fiber series Pyrometer gauge, Oil pressure gauge, Voltage gauge, & Boost gauge, 2 AEM wide band 02 gauges
Lights: Sylvania Silver Star High and low beams
Cooling: PWR 4 core aluminum radiator, Twin Zirgo electric fans w/aluminum shroud
Plans for the future? Install my adaptronics stand alone, new injectors and a 10 lb pulley. Next phase will be a all forged 4.7 liter with a twin screw on top of it. Maybe a new paint job?
Its never done!
Lots more cool stuff not listed!
Old 05-24-08, 03:45 AM
SC400TT
SC400TT's Avatar
Username: SC400TT
Year: 1993
Model: SC400
Details/Supporting Mods:
Engine
Built Balanced and Blueprinted 1UZFE
Ross Forged Pistons, 8.5:1 compression
Pauter Rods
Race Main Bearings
ARP Head Studs
ARP Main Studs
Supra TT Valve Springs
8 960 CC Delphi injectors
WolfKatz Custom Fuel Rails, anodized black
Dual In-Tank Walbro 255 Fuel Pumps
MVP Dual Zirgo fans with polished aluminum shroud
Dual Greddy Billet Catch cans
Koyo Aluminum Radiator
Powder-Coated radiator pipes
Aeromotive Fuel Pressure Regulator
Polished Valve Covers, Timing Covers and Intake Manifold
Powdercoated Throttle body, chrome trim
Turbo setup
Dual Bullseye Power S256 Turbos with 38mm Integrated Wastegates
TurboSmart 50mm BOV
Autronic SM4 Stand Alone Engine Management
Phoenix Tuning Custom Plug-N-Play Wiring Harness
DEFI Link Boost, Oil Pressure, EGT Gauges, 52 mm
AEM Wideband UEGO Gauge
Greddy PROFEC B-SPEC 2 Boost controller
Custom Garrett Core Bar n Plate FMIC
Transmission
BoostLogic Race Built transmission includes BL Billet Forward Clutch
PCS (Powertrain Control Solutions) Stand Alone Transmission Management
Custom E-Shift/4 Speed Gated Shifter
B&M Transmission Cooler
2800 RPM Precision Industries Dragon Torque Converter
TRD LSD Stock 3.23 Gears
Exhaust
Mike Young/F&I Performance Custom 4-2-1 Stainless Steel Manifolds
Mike Young/F&I Performance Custom Stainless Steel Up pipes
Mike Young/F&I Performance Custom 3” Stainless Steel Split Y Downpipe with Single Flex Tube
Mike Young/F&I Performance Custom Stainless Steel 3" Custom Midpipe with Single Flex Tube
Mike Young/F&I Performance Custom Stainless Steel 3" Dual Exhausts
Dual Greddy Stainless Steel Mufflers.
Suspension
Daizen Camber Control Bushings
Daizen Front and Rear Sway Bars
TEIN FLEX Coilovers
EDFC
Brakes
Willwood Custom BBK Front and Rear
Precision Custom 2 Piece Rotors
Stainless Steel Brake Lines
Interior
2000 Black OEM Swap
Pattern Tek Wood Redesign
Lexus OEM Black Perforated Leather 3-Spoke Steering wheel with E-Shift
Custom Perforated Suede Headliner and Visors
Custom Perforated Leather Door Inserts
LexTech Lighting LED's
Vlamos Custom Lexus Sill Plate
Stereo
Pioneer AVIC Z2 GPS/NAV Double DIN Head Unit
MB Quart 3-Way and 2-Way separates
JL 10" Sub
Alpine V-12 5-way and Mono Amps
Custom Shark Fin with Stealth Stubby Antenna
Pioneer XM
Body
SK Customs PPG GLobal Black Paint and Clear
Seibon CF Hood
SK Customs Custom Mounted Aston Martin Wire Mesh Hood Vents
Lexus 97/2000 Complete OEM Refresh
SK Customs Custom molded Big Win Lip
Shaved Antenna
SK Customs Custom Cut rear fender wells
Wheels/Tires
Altstadt Type 1 Split 5 spoke Forged 2-Piece Wheels in Chrome and polished lips, 18x8.5 Fronts, 18x9.5 Rears
Bridgestone Pole Positions
and the other set
iForged Classic 20" High Polish staggered wheels
Lighting
Lexus OEM headlights with Custom E39 HID Retrofit
Advanced Automotive Concepts CCL Halo RingsRings
Takakaira Clear JDM Front Side Markers
TBD
Best Track Time if known
TBD
Other Mods
Listed
Finish and Debut at FL2K9 in July 2009
Show at HIN in Miami
Show and compete at Lexus V8 Shoot Out in 2009
Drive and Enjoy
Old 05-24-08, 10:01 PM
ScottURnot
Super Moderator
ScottURnot's Avatar
OK, I have it updated some
Old 05-25-08, 07:28 AM
KC95SC400
KC95SC400's Avatar
Cool guys, we're getting there! I know there's at least a few more.
Do you guys with the roots blowers have any idea what your intake temps are? Just curious because I've taken out the intercooler again, probably for good this time. I've updated my dyno numbers to reflect the change. Also updated a couple of other little things.
KC
Old 05-26-08, 06:41 PM
twizted
twizted's Avatar
Username: Twizted
Year: 1993
Model: Lexus sc400
Type of FI: Ported m112 cobra s/c
Details / Supporting mods: 2.5" exhaust with dynomax ultraflos, ss headers, rising rate fpr, aem fic, custom intake piping, koyo tt radiator,
Best Dyno #'s if known: Don't know yet, installing all this stuff and tuning soon. Updating from m90 setup
Other mods: lots of body work, interior stuff, 20" staggered wheel, bbk
Plans for the near future: More boost!
Old m90
Old 05-31-08, 10:10 PM
rdm20fan
rdm20fan's Avatar
Username: RDM20FAN - "Bob"
Year: 1993
Model: Sc400
Best Dyno #'s if known: 510-rwhp 501?-rwtq 17psi (Auto Tran)
Best track time if known: 12.6 @ 124.9mph (Autometer D-Pic) 13.1 @ 118mph (Track time as she melted a piston :-( on the auto tran.)
Other mods: Supra TT Calipers, Supra TT auto rear carrier, Dual 3" exhaust, 6-speed Getrag Trans
Old 06-09-08, 08:13 PM
KC95SC400
KC95SC400's Avatar
Ya, I saw the video on youtube, it was painful to watch.
KC
KC95SC400
KC95SC400's Avatar
I know there's a couple of more, come on guys!
KC
Old 06-10-08, 12:12 PM
SuprRunner
SuprRunner's Avatar
Username: SuperRunner
Year: 1993
Model: SC400
Type of FI: M90 air/water intercooled
Details / Supporting mods: M90 supercharger from Ford T-bird. Top mount outlet to a custom air/water intercooler setup. Completely custom intake manifold with larger runners and large radius ports. Going to try the 2.5" pully, and might even go with some 440cc injectors+Map ECU.
Other mods: Vertex body kit - 19" rims- nothing else.
Plans for the near future: Finish the car, work in progroess
[img]Still not driving yet. Man things take A LONG TIME to do.
Here is the back of the intercooler
Old 06-15-08, 08:42 AM
KC95SC400
KC95SC400's Avatar
Updated track times, ran the quarter last night.
KC
Old 11-07-08, 03:16 PM
Blown SC
Blown SC's Avatar
Username: Blown SC
Year: 1991
Model: Soarer UZZ31
Type of FI: AutoRotor Twin Screw @ 15 psi ( No Intercooler ) 98RON Pump Gas
Details / Supporting mods: R154 Trans ( Soon to be T56 Tremec 6 Speed ), Adaptronic ECU, Supra 3.2:1 Diff, My Large Extractors, 2 1/4" System ( Nothing fancy ),
Best Dyno #'s if known: 355RwHp ( 270RwKw )
Best track time if known: Not run on Track or Strip in this trim yet. ( 1/4 mile 5 years ago on 6psi with stock ECU 13.5 ET )
Other mods: Celsior front 4 pots / Supra rear 2 pot Calipers, with stock rotors ( These have worked well on the Track Days )
Plans for the near future: 6 Speed T56 Tremec before Xmas ( MY Development ), MY new Blower Manifold and run upto 20psi with no cooler ( But I will blend some Martini Racing 1400 fuel intro the pump gas 98 RON )
* Same setup in my Drag Silvia with a stock auto trans * { Pulled 11.4 1/4'ers so far **
Quick Reply: Club Lexus FI V8 list
