07-18-08, 09:07 PM
#121
also new pressure plate and clutch disc.
__________________
1992 sc300 1jz Single Turbo R154 Much faster then the Porsche
2004 Chevy 2500 duramax
1986 porsche carrara 85,000 original miles
07-18-08, 09:12 PM
#122
heres my new trust Supra downpipe(FITS perfect) and my duel 3"inlet to 4"outlet magnaflows are on the WAY
__________________
07-18-08, 09:49 PM
#123
1995 Lexus SC
Nice looking collection there! So does the Supra downpipe bolt directly up to the stock exhaust?
08-29-08, 09:17 PM
#125
any news on the trans noise?
__________________
97 SC300-Platinum/Black-R154-TT LSD-Cusco Zero 2e Coilovers- LS400 Front BBK- TT Rear BBK- Daizen Sway Bars- TSX Retrofit- Supra TT wheels- Spec Stage 2+ clutch/Toda Lightweight flywheel- Cusco Strut Tower Bar- Blitz NurSpec Exhaust- Katzkin Leather Seats- 5000K Foglight HID'S
08-29-08, 10:03 PM
#126
im subscribed! great thread, and awesome work
__________________
i roll fenders for SD
08-31-08, 12:20 PM
#127
update
the transmission and my rear end needs to be replaced. i replaced the clutch, master and slave cylinders and it fixed the chattering problem. but there is a lot of play in the transmission. for instance if i have the car in gear and the e brake pulled i can move the drive shaft about 1/2 inch forwards and backwards.
Another issue is after my exhaust install there is a bit of white smoke that comes out the exhaust. it mostly happens when i come to a stop, as far as i know the smoke is white because i haven't let anyone drive the car to get a look at the smoke. i cant really get it to smoke in neutral revving it. i think it might be the turbos because they are loud and whinny in my opinion. i think i am going to buy a wideband just to be sure
__________________
09-01-08, 12:27 PM
#128
parts for sale
i also have parts for sale listed in this F.S. thread. i also have a soarer clip sitting in my driveway. so if there is anything unusual that i would be able to find on my soarer clip i will send to help out a fellow sc owner. http://www.clublexus.com/forums/sc400-300-classifieds/375264-sc-and-1jz-soarer-parts.html
__________________
09-01-08, 01:57 PM
#129
gdc5ind, anyway you can tell me how far your fork moves when you depress the clutch? I'm having a hell f time with mine, and everything is brandnew..
09-04-08, 07:09 PM
#130
New Exhaust
the custom exhaust cost 995$ the specs are 3.25" downpipe with 3" y pipe and two magnaflow 3" inlet to 4"tip mufflers. here is a quick clip just to give and idea of the sound. i think this is the best look for the money i spent. http://www.youtube.com/watch?v=Lp0UiKxec0k
__________________
09-05-08, 12:39 PM
#131
funniest thing i have ever seen!
thought you guys would like this. there seems to be some people of this nature around this forum. http://videos.streetfire.net/video/R...own_180115.htm
__________________
09-17-08, 12:40 PM
#132
__________________
09-18-08, 04:25 PM
#133
1995 Lexus SC
Exhaust looks pretty good. Is it driving better yet?
09-18-08, 04:35 PM
#134
yea i am keeping up with g35's and sti......  i am stock other then the exhaust.
__________________
10-03-08, 07:37 PM
#135
How's the 7mgte driveshaft so far? Did you just need the front half or both piece? And was your sc originally an auto tranny...
Tags
1jz, 330, clutch, compression, cylinder, engine, gauge, hold, ohm, r154, rating, sale, sc300, stock, swap, tach, temp, torque  |
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
