2jz-ge and nitrous questions...
I have a 96 SC300, and I plan on swapping the car with a GTE motor. I feel bad about taking the good motor out even though its at 188k miles. So I planned on throwing some nitrous on it until it gives. I am going to run a ZEX wet kit. I dont want to try to blow it up, but have as much fun with it until it goes. I figured id be running nitrous with the gte motor anyway here are my questions-
1- How big of a shot can this handle?
2- What would you do to set this up correctly (tuning equipment etc...) ?
any advice for me from anyone that has done this would be awesome...
Look at post #15, i gave some decent info there...
https://www.clublexus.com/forums/sho...d.php?t=328125
you should be able to handle a 75 shot no prob, after that you have to monitor fuel pressure depending on the condition of yours. You could probably do a 125 shot with a walbro pump and running 1 step colder plugs. As long as you get the safety equipment like a fuel pressure cutoff switch and throttle switch it will be pretty hard to screw things up...
hope this helps
hope this helps
