Synthetic Oil Benefits?
Ok.. I have a well maintained SC300 with 95K. I've been changing the oil myself for my Harley w/ Valvoline Synpower. I thought, maybe i should make the change for my SC, to Mobil 1.
For all that have made this change. What benefits do you experience?
Thanks.
Thanks.
1st choice is amsoil....just read the link its all there
25,000 mile or once a year normal service, 15,000 miles or extreme conditions just read
https://www.amsoil.com/storefront/asl.aspx
second choice is royal purple
do reasearch mobil 1 is not 100% synthetic
runs smoother, better gas milage...ect
From what i understan synthetic oils give you better gas milage fewer oil change better idle/smoothness etc. I use royal purple and a toyota filter .My turbos come on alot better with rp 15-40 rather than conventional oil.
"Is Mobil 1 with SuperSyn Technology a fully synthetic motor oil?
Yes, it is. To meet the demanding requirements of today's specifications (and our customers' expectations), Mobil 1 with SuperSyn uses high-performance fluids, including polyalphaolefins (PAOs), along with a proprietary system of additives. Each Mobil 1 with SuperSyn viscosity grade uses a unique combination of synthetic fluids and selected additives in order to tailor the viscosity grade to its specific application."
^^^ ridox
read this about mobil 1 and others
http://www.synlube.com/synthetic.htm
worth the read if ya use mobil 1
heres an article i found on mbworld about oil brands.
http://mbworld.org/forums/showthread.php?t=238674
1) AMSOIL
2) BP Visco 5000
3) Mobil 1
4) Mobil 1 (difference being price)
5) Hi-Tec HTO
6) Shell Helix Ultra
7) Royal Purple
8) Castrol R
9) Castrol SLX
10) Torco”
1) AMSOIL
2) BP Visco 5000
3) Mobil 1
5) Hi-Tec HTO
7) Royal Purple
8) Castrol R
9) Castrol SLX
10) Torco”
I have found that using 0W40 Mobil 1 helps compression, even better than the 10W40 in the dino oils.
There are a lot of other factors, and thing being changed in modern oils; the wear additives have come under fire, and have been eliminated/reduced in many oils lately. I have a spreadsheet that someone else has made with a breakdown of many oils, I'll try and find it and post it up if you want.
aljodoro
GX - 1st Gen (2004-2009)
13
10-16-11 04:27 AM
