SC400 Hydraulic Pump Bolt Size?
While bolting everything back on during my timing belt and water pump change, I managed to break one of the bolts that hold the hydraulic pump on.
The pump is held on with 2 bolts and 2 nuts. Luckily, the bolts are the same size. I think it is an M8 x 1.25 x 105. Can anyone confirm that for me?
Any recommendations on where to buy a bolt of this size? Ace Hardware?
Unfortunately, I now have to remove just about everything (maybe even the water pump) to get at the broken bolt with the extract bits.
I did confirm that is the correct size. I ended up finding it at NAPA. It's actually 5mm too long, but I'll washer it up and it'll work out.
On a side note, while trying to extract that bolt, I broke the extractor off inside the bolt. Now I've got to drill through that hardened steel with a carbide bit. Luckily, it's not in there very deep.
Wish me luck.
Wish me luck.
