Injector wiring
Old 02-28-08, 08:14 PM
craaaazzy
craaaazzy's Avatar
Default Injector wiring
hey guys,
i'm not an electronic wiz so i need help wiring a mkiii resistor box. my question is: how do i tell which of the 2 wires from the injector is the power or from the ecu? thanks.
Old 02-29-08, 07:17 AM
Dx3
Dx3's Avatar
Originally Posted by craaaazzy
hey guys,
The black/orange is the power.
You will just take power out of one of the 6 black/orange wires as you don't need it for every injector.
Jonny
Old 02-29-08, 11:03 AM
craaaazzy
craaaazzy's Avatar
thanks jonny. time to upgrade to larger injectors. =)
Old 02-29-08, 11:40 AM
Dx3
Dx3's Avatar
Just make sure you get injectors that fit your rail. Mine don't so I have to wait 3 weeks for the machine shop to bore out my fuel rail properly
Did you understand what I meant about using just one power wire on the injectors? Just cut and tape off the other ones so they don't get in the way...
Jonny
Old 02-29-08, 12:12 PM
craaaazzy
craaaazzy's Avatar
got precision ones, mitsu style which should drop right in.
yes, understood. i did further research last night. from my reading and what you've just stated, i just need to pull one power wire from one of the injectors, tape the rest off, then connect each of the remaining wires from the box to two of the injectors. i believe 1-2, 3-4, and 5-6. running AEM btw. correct me if i'm wrong.
Old 02-29-08, 12:41 PM
Dx3
Dx3's Avatar
I don't know if the MKIII and MKIV resistor box are different - but this is not how mine is done.
I have power to power, then one side of each injector plug goes to the resistor box, and the other side goes to the ECU. I am also running an AEM.
Jonny
Old 02-29-08, 04:04 PM
craaaazzy
craaaazzy's Avatar
so your running a mkiv box. i'll do more research...
Old 03-02-08, 07:52 AM
Dx3
Dx3's Avatar
Yeah, I did some reading. The MKIV box has 6 wires + 1 power. I guess the MKIII box has 3 wires + power.
Good Luck man,
Jonny
M.Rad.
03-08-16 09:52 AM
6SOARER
11-18-13 08:27 AM
6SOARER
09-03-13 09:25 AM
shaodome
16
06-23-09 09:59 AM
That-Guy
14
01-18-09 02:30 PM
Quick Reply: Injector wiring
