boost controller install
I have a Greddy Profec Spec B boost controller and had a question on install. I know where all the hoses etc go. How did you all run the hose inside the car to the engine bay? I was just thinking to cut a hole in the firewall to get the hose and wires through it. I can't run it where the ECU wires go, seems to me it will kink. So my question is.. where did you all run the hose / wires.
I quick question. . . I know you put a T in between actuators and then take that 1 host and bring it to the solenoid, but on the other side of the solenoid you are suppost to use turbo compressor pressure, when thats the there "stock" actuators went to before I unplugged them. My question is.. Do you put a T on the turbo compressors also? Or do I need to just run 1 compressor and put a cap on the other? Thanks !
i'm trying to run a boost gauge and mount it under the climate control
i kno whee the ecu is and wire the wires are heading but have no clue where they go and where they enter the engine bay
same goes for the hole by the brake pedal
Jonny
