Suddenly lost 4 cylinders??
Old 01-30-08, 08:45 PM
mr2tosc4
mr2tosc4's Avatar
Default Suddenly lost 4 cylinders??
I was on my way home doing just 35 running smoothly when I stepped on it a bit to go to 45 the car suddenly lost power like half of the V8 suddenly died. I slowed down then I heard the usual sounds you hear whenever you turn off the engine (like ticking sounds from underneath the car which is normal when you turn off) but I still had the car running at 15mph at that point and that's how fast I went for 2 miles til I reached my house. It did not die on me. Popped the hood and all belts were fine, it's just idling lower than usual and felt like I only had 4 cylinders firing. Now I heard about coils going bad that can cause it, but I want to get very clear on it before I start tinkering with it tomorrow. Anybody had the same problem? 1993 SC400 btw. Thanks.
Old 01-30-08, 08:49 PM
RedPhoenix
RedPhoenix's Avatar
Igniter/Coil
same problem, easy fix. Happened the WEEK i bought the car lol.
Best way to test is unplug one of the ignitor/coils.
1) Start car.
2) Does it start?
Yes? Go to 3. // No? Then the one you unpluged is the GOOD coil
3) Plug that one back in and unplug the other
4) Does it start?
No? Then the one you just unplugged is the GOOD coil. //// Yes - sorry, I dont know, keep looking.
Old 01-30-08, 08:52 PM
5sp_jzz30
5sp_jzz30's Avatar
thats what i do
Old 01-30-08, 08:54 PM
mr2tosc4
mr2tosc4's Avatar
Thanks RedP, saw your reply to the other post too and that's where I got the idea that the coil might be the culprit. Hope it's that and not the other dude who went through 7 shops to get his sc fixed.
Old 01-31-08, 06:24 AM
RedPhoenix
RedPhoenix's Avatar
Hopefully its just this. Basically its trial and error
Old 01-31-08, 06:58 AM
sphy1005
sphy1005's Avatar
i had the same problem when i had my sc4. It was my coil. Ck for spark?
Old 01-31-08, 08:15 AM
mr2tosc4
mr2tosc4's Avatar
Removed LH side ignition coil (side near battery) car started then died. So the RH side IC is good I assume? I'll put back LH side then pull out RH side now.
Old 01-31-08, 08:24 AM
mr2tosc4
mr2tosc4's Avatar
Ran out of time, will do other side tomorrow. RedP, the car started but died in 2 secs, that means the side I did not remove is good right? Thanks.
Old 01-31-08, 11:42 AM
RedPhoenix
RedPhoenix's Avatar
Im not sure if the car should start or not.
however, the one that you pulled (battery side) is good.
try the other side however.
Matt
Old 01-31-08, 02:20 PM
aliga
Former Sponsor
aliga's Avatar
coil or ignitor, seen it so many times. i have both if you need it
Old 01-31-08, 07:57 PM
mr2tosc4
mr2tosc4's Avatar
Thanks Gaz. Need to find out which side I need first, but it also might be a good idea to have a spare laying around. I'll find out first tomorrow then give you a call and hope Al's available this weekend so I can pick up.
Old 01-31-08, 08:30 PM
aliga
Former Sponsor
aliga's Avatar
al will take good care of you, he had this same problem you were having.
Old 02-02-08, 10:25 PM
mr2tosc4
mr2tosc4's Avatar
Problem solved. It was the LH ignition coil. Dropped by Gazi's boy Al in MD and Gaz hooked me up with both coils + other goodies I needed. All 8 pistons back up and firing like nothing happened. Awesome deal Gaz, keep up the good work, we appreciate it fully!
Oh thanks to RedP too for the old school diagnostic test, who needs codes??
charger980
13
08-14-13 02:10 PM
SC93
36
08-06-13 05:19 PM
soflo99
94
06-13-13 09:35 AM
Toughguy48
SC- 1st Gen (1992-2000)
10-25-10 10:14 PM
Quick Reply: Suddenly lost 4 cylinders??
