Any experiance with with these transmissons?
REAR WHEEL DRIVE
* Valve body is custom calibrated to provide the ultimate in clutch application power and clamping force (The modifications performed by us are a proprietary design and are unavailable elsewhere)
* Virtually indestructible Raybestos Blue Plates are installed in all shifting clutches
* *NEW FEATURE* We have now developed the industry's only 6 friction disk C-2 clutch pack for a 50% increase in third gear holding capacity.
* New one way clutches (sprags) are installed in all locations
* Planetary splines are heat treated to prevent stripping
* Metalax treatment is applied to input shaft to eliminate stress related failure
* Sun shell is heat treated to prevent spline stripping
* New design high flow solenoid assemblies are installed
* Lube system is redesigned to provide increased flow and cooler operation
* Performance pressure regulator boost valve is installed to prevent sluggish line pressure rise and to increase clutch holding ability.
NOTE: This unit is the strongest configuration that can be achieved with this Toyota transmission. However, if you are running much faster than 9.99 we recommend the installation of a domestic three speed or Powerglide transmission. These units also enable you to enjoy the many benefits of a Trans Brake and 8", 9", or 10" torque converter. See our specialty RWD section or call us for details.
A340, 93-up 30-40LE, A340E, A340F, A340E, JEEP AW4: $3075
A341E and A340E, Lexus, Supra 2JZ-GTE: $3275
LEXUS A650E: $3675
TOYOTA A750E: $3775
A340H (Early 4Runner type with integral transfer case) - call for pricing
Please call or email us to order a complete transmission.
Heres the site...
http://www.importperformancetrans.co...uto.shtml#main
Its great, transmissions, tourqe converters all kinds of auto goodies
LEXUS A650E: $3675
TOYOTA A750E: $3775
Heres the site...
