Need Help! What do i need for complete r154 swap
Old 12-23-07, 04:47 PM
marek955i
marek955i's Avatar
Default Need Help! What do i need for complete r154 swap
Just like to the title says, I recently purchased an r154 out of a older supra. I also just got a 1jz bellhousing. My question is, do i need a 1jz clutch, pressure plate and fly wheel or a 2jz. If anyone could help it would be greatly appreciated. Also, do i need a diffrent drive shaft or will my stock one fit?
Thanks
Old 12-24-07, 03:29 PM
marek955i
marek955i's Avatar
Anyone? Please.
Old 12-24-07, 04:13 PM
lexforlife
lexforlife's Avatar
irecently finished my auto to r154 swap
you will need a 89 to 91 supra mkIII (7mgte) pressure plate now depending on your YEAR your r154 is from u will need either clutch from na mkIII supra or from mkIII turbo mine i had to use from na mkIII supra BECUASE THE OUTPUT SPLINE WAS LARGER on the na so be prepared
Old 12-24-07, 05:41 PM
Blizzy
Blizzy's Avatar
At a minimum, you will need:
- MK3 Turbo front driveshaft
- 1JZ Flywheel
- 7MGTE/1JZ Clutch Kit
- Shifter Housing extended
The last option leaves you with several options, none of which are walks in the park. But, for a 600wtq capable transmission, it is a small price to pay.
Old 12-24-07, 06:31 PM
lemmiewink
lemmiewink's Avatar
I have not heard about that na clutch disk issue. What year models need the na? I bought a gte pressure plate/ clutch disk. And the disk seems to fit the spline just fine.
For the OP, are you going auto to manual conversion? If so you'll need the parts corresponding to that conversion (pedals, mkiii slave, hard lines, etc.)
For your driveshaft question, it also matters if you are doing the auto to manual conversion. You must use the rear half from a 5spd sc300. and mate it to a front half from a 7mgte mk III supra. The rear half of the drive shaft from an auto sc300 is too short when mated to the 7mgte driveshaft.
Note this though: i bought a supposed Soarer driveshaft ( which i assume is a direct fit), and for some reason the input shaft doesn't fit into my r154. So I will be swapping input shafts and seeing if this is the right length. If the driveshaft that I have is indeed from a soarer then you can't use a soarer input shaft with a mkIII r154.
Also, my r154 is from a JDM MKIII which came with the 1jz.
Old 12-24-07, 10:30 PM
32SC
32SC's Avatar
according to this thread, the auto and 5spd rear driveshafts are the same length
https://www.clublexus.com/forums/sho...d.php?t=275016
I'm hoping this is true because it will save me a lot of time and money
Old 12-25-07, 01:22 PM
marek955i
marek955i's Avatar
Thank you guys. I had a stock w58 and it just does not hold the power that iam putting to the wheels. I have replaced two transmissions since i got the car in May. Will the whole front drive shaft be needed or just the front youlk?
Old 12-25-07, 01:34 PM
SCoupe
SCoupe's Avatar
Hey marek,
What is the sustained dyno'd realistic RWHP number that blew two w58's. How were you driving this thing?
My w58 has been solid for over a year, not exeeding 410 rwhp 395 wtq, though I don't hold it at those levels long.
Old 12-25-07, 06:44 PM
marek955i
marek955i's Avatar
The car is a t67 that dynoed 495 horse. I still need to get the car dynoed up here in chicago . The previous owner told me that he blew two w58 too so the power needs a stronger trans.
Old 12-25-07, 11:43 PM
lemmiewink
lemmiewink's Avatar
http://www.clubna-t.com/forums/showthread.php?t=2994
heres my source. Look near the end when somone used an auto drive shaft and it came up short about 2 cm. hmm well your link does have pics in it, and they do appear to have the same rear shafts. So if thats true then go for it. I have no hands on experience in this case so all I know is what I read.
Old 12-26-07, 07:39 PM
32SC
32SC's Avatar
I've read that thread before (I've followed it since it was first posted) but the conclusion they came to was that something in the auto drivetrain setup is a different length from the 5spd drivetrain. Does anyone who has completed an auto -> r154 swap have any input?
Old 12-27-07, 11:26 AM
dumdumgreg
dumdumgreg's Avatar
How much did you guys spend on all your parts inlcuing clutch and shifter extensions?
not including installtion labor
Thanks
Old 12-27-07, 12:47 PM
marek955i
marek955i's Avatar
I bought the R154 for $380, with noly 80k on it. The bellhousing was $250, the extension is going to be $50 and clutch and flywheel $500+ depends what kind i decide to go with
sucessr1
08-26-14 06:50 PM
meangreen1
SC- 1st Gen (1992-2000)
02-17-11 09:45 PM
sc300bigtx
SC400 / 300 Classifieds
12-15-10 11:31 PM
madmax98
08-12-08 12:19 AM
ummagawd
29
01-09-06 04:39 PM
Quick Reply: Need Help! What do i need for complete r154 swap
