Dyno'd the 1J this weekend (dyno plot attached)
Old 11-05-07, 02:00 PM
shern
shern's Avatar
Default Dyno'd the 1J this weekend (dyno plot attached)
So some of you may have seen that we ran a dyno day down here in beautiful Arizona this weekend (LEXAZ event). Big thanks to Chris (Kaiser) for organizing the event and Keith at the shop for letting us use his dyno.
As far as mods are concerned, they include:
1) 1JZ-GTE w/ factory twins
2) cat delete with full custom Magnaflow exhaust
3) Greddy Profec Type-S boost controller
4) 24"x12"x3" front mount intercooler
5) 440CC injectors
6) cold air intake (in the front bumper) with AEM dry flow
7) W58 tranny
With 13PSI, I was able to hit 289whp and 292wtq.
If you look at the plot, you'll see I'm running super rich ~10.5 A/F. I have some room with A/F to gain some extra ponies but I'll need to go to an AFC which I plan. I'd like to hit 300whp/300wtq!
Also, raising the boost yielded no gain in power, implying 13PSI is pretty much the limit of the twins on my motor.
Plot:
Old 11-05-07, 03:22 PM
Blizzy
Blizzy's Avatar
Stick to 13PSI, but trim the fuel delivery with some tuning so that you can get into the 3xx whp/wtq. Nice baseline dyno!
Old 11-05-07, 03:30 PM
yelloa3gti
yelloa3gti's Avatar
nice number? too much injector maybe?
Old 11-05-07, 07:51 PM
Luxor
Luxor's Avatar
nice #'s man, I still wanna get a ride! hehe
Old 11-05-07, 09:57 PM
TTSC3
TTSC3's Avatar
Yeah, with a bit of tuning and a boost controller, not to raise boost, but just to control the wg, you could make a bit of low end tq, and bring peak power up to about 310-315whp, with the tq going up about 15wtq as well. The powerband on the 1J/2J is so linear with the stock twins and no boost controller, but it still feels very quick. Nice numbers though, congrats!
Old 11-06-07, 06:22 AM
Kaiser
Kaiser's Avatar
Shern - don't forget we are going to fix that boost leak we found after the run. That coupled with some fuel trimming and I think you'll make it over the 300 mark. I'm pretty sure it's your bypass valve opening when you turn the boost up over 13psi and the reason for that is the boost leak is so close to the valve and the spring alone can't keep it shut.
Old 11-06-07, 06:41 AM
plex
1UZFE/2JZGTE
plex's Avatar
Nice I did 272rwhp when I had twins with the same mods except I was on stock injectors and 10 psi.
Old 11-06-07, 08:02 AM
shern
shern's Avatar
Chris
I was thinking the same thing about the diverter valve. If this is the case and the valve is not letting me go past 13psi, there may be hope with boosting a little higher. Time for a blockoff plate and BOV! Tial, here I come!
Old 11-06-07, 02:30 PM
atekt
atekt's Avatar
Congrats man! Pretty good numbers
Old 11-07-07, 10:51 PM
1JZ300
1JZ300's Avatar
nice numbers with stock twins.....impressive, when you going single ?
Old 11-08-07, 04:51 AM
shern
shern's Avatar
Thanks
To be honest, I think if I can join the 300/300 club, it will be enough for now. I'd like to get the body kit going,upgrade the suspension to coilover and get aggressive on a new wheel fitment. After those are complete, I will look into going single. 300whp is pretty darn quick for the street.
Old 11-08-07, 05:37 AM
sc250tt
sc250tt's Avatar
Originally Posted by shern
Thanks
you can acheive this with stock injectors and more boost stock turbos dont need more fuel than what the 370's flow .if it does you might want to get a fuel pressure regulator.
Old 11-08-07, 10:18 AM
Curry
Curry's Avatar
Very nice numbers! Im sure you'll get a few more horses if you throw an emanage or AFC into the mix.
Old 11-08-07, 10:25 AM
plex
1UZFE/2JZGTE
plex's Avatar
Thanks
I used to think that before I owned a turbo car lol.........
Old 11-08-07, 10:29 AM
shern
shern's Avatar
I wondered how long it was gonna take for somebody to chime in on that.
NOTE TO SELF: "I will not test drive a 500whp car, I will not test drive a 500whp car......"
Quick Reply: Dyno'd the 1J this weekend (dyno plot attached)
