Calling out peeps with dead Alt + Battery.
ok i was wondering.. after your alternator dies... followed by the battery..
after getting fixed did anything else go down? reason why im asking is because.. after everything was finally fixed.. my gas needle stays on E.. even after a full take fill up..
can anyone help?
can anyone help?
Sorry, accidentally hit the enter bar. I recently received a sales flyer from a company that rebuilds import ABS systems and gauge clusters, and they mentioned that the LS Lexus commonly had dead fuel gauges. Thepic. of the cluster looked just like ours.
ok so... been reading the manual... tried absorbing whatever i can.. kinda hard since im not that great reading diagrams n ish.. but yea..
ok so the book said to check the fuel sender thing... problem is.. thats in the gas tank soooooo.. imma have to check that later when the gas is really low.. n the problem wit that is.. iono when the gas is low sooooo.. when i reach 3xx ,miles.. its time to open her up.
on other news..
i found the fuses for the Gauges.. checked it.. looks fine think. also if u notice that red wire hanging loose.. what is that O_O?? since that was on the gauge fuse.. but i removed it since it looked wierd..
ALSO
WHAT THE F!!
IS THAT!
ive noticed.. when i bump the black box
That thing (see the clear box) beeps green.. n when i hit it.. it beeps red.
hah... hope its not a bomb.
edit.. sry for crappy pics.. had to use my phone + nightshot + Flashlight
on other news..
ALSO
WHAT THE F!!
IS THAT!
Maintenance Moderator
yup, thats a shock sensor for an aftermarket alarm... red wire - no clue- possibly an antenna for said alarm, but hard to say for sure... you don't have to get in the tank to check the sender - just get to it on the outside, unplug it, and check the resistance... you should notice it change resistance as you have different levels of gas in the tank....
SWEETSOUND2001
01-11-02 05:23 AM
