VSS Wire (Vehicle Speed Sensor Wire)???
Old 10-25-07, 09:21 PM
TTSC3
TTSC3's Avatar
Default VSS Wire (Vehicle Speed Sensor Wire)???
Does anyone know which pin the VSS wire is on a '92 SC300?? I've looked, and looked and come up with nothing. I'll take what I can get at this point. Whether it's at the ecu or behind the cluster, I just need it at this point. I'm trying to get my Navi to work, and can't get a for sure answer. I found some pic of a '98 model, but I'm sure it's different. Also, my car has a GTE swap with the 2JZGTE M/T ecu. I found the VSS wire for a Supra, so should I assume that it's the same pin on the SC? If anyone knows, please DO TELL! Thanks!
Old 10-26-07, 12:35 AM
TheMole
TheMole's Avatar
This may or may not help:
Old 10-26-07, 01:00 AM
TTSC3
TTSC3's Avatar
Yeah, that shows it as pin A2, which is what I'm reading is correct for a Supra. Now, I do have a GTE, M/T, supra ecu in my car for my GTE swap, but I'm running a W58, so I wasn't sure if the pin was still the same on the ecu itself. If the VSS pins are the same for N/A and turbo models, than it should be the same for the SC, right? If anyone has any additional info/input, feel free to chime in. Thanks again!
Old 10-26-07, 06:15 AM
Dx3
Dx3's Avatar
The SC300 GE motor has the VSS at A2.
Jonny
Old 10-26-07, 06:24 AM
TTSC3
TTSC3's Avatar
Jonny
So turbo & N/A have the same pin location for the VSS even on the early model, OBD1 SC's? Just clarifying. Thanks again for the help/response.
Old 10-26-07, 06:32 AM
Dx3
Dx3's Avatar
Yes, the Supra/SC300 2jz NA motor shared the A2 pin location for the VSS
Jonny
Old 11-05-07, 12:24 AM
miraluna
miraluna's Avatar
Stupid question, where is A2 pin located... under the steering wheel... driver side???
I have Z2 and couldn't find VSS location and didn't hook it up yet...
Thank you in advance...
Doug
Old 11-05-07, 06:03 AM
Dx3
Dx3's Avatar
Doug
If you peel back the carpet on the passenger side you will see your ECU. It connects there...
Jonny
Old 11-05-07, 07:49 AM
TTSC3
TTSC3's Avatar
Yep, thanks again for the wire help. It is DEFINITELY pin A2. Also, I believe pin A2 is the solid pink wire behind the cluster on the middle plug.
Old 11-05-07, 08:06 AM
Dx3
Dx3's Avatar
No problem man - glad I could help
Jonny
Old 11-05-07, 03:23 PM
miraluna
miraluna's Avatar
Cool.. I will hook it up Wednesday... 92 SC300 wire should be same??? no???
Thanks
Old 11-05-07, 03:53 PM
TTSC3
TTSC3's Avatar
Thanks
Yes, N/A and turbo are the same.
Old 11-09-07, 02:31 PM
miraluna
miraluna's Avatar
I peeled off pass. carpet and found that there are about 6 plugs and also there were about 6 pink wires... Am I stupid or what????
Help Please!!!
05ls430518
02-12-18 10:23 AM
scmaluco
12-14-15 07:15 AM
SCereal
SC- 1st Gen (1992-2000)
03-19-10 08:39 AM
TurboSCLex
05-07-03 05:30 AM
Quick Reply: VSS Wire (Vehicle Speed Sensor Wire)???
