Auto Supra TT Diff Installed (LSD and 3.76 gears)
Old 11-16-07, 08:14 PM
  #46
97-SC300
97-SC300's Avatar
yes do it that way. its the best way and thats how the instructions tell you to do it in the manual for the yellow box.
Old 11-16-07, 09:52 PM
  #47
TheMole
TheMole's Avatar
Originally Posted by Blk97SC300
thanks a lot bro.. but I have no idea how to read that thing lol.
How do I know which wire I need for the speed sensor? I see some in the upper left corner of the pic- which one?
Yea those wires coming out of the top left 'Vehicle Speed Sensor'. If you notice there are letters besides each wire. They denote the color of the wire.
Y=Yellow
L/R=Blue w/ Red stripe
R=Red
Old 11-16-07, 10:58 PM
  #48
Blk97SC300
Blk97SC300's Avatar
ok so i disconnected the yellowbox from the pink wire (VSS) on the ECU.
I simply connected the yellow box directly to the speed sensor on the transmission..
works like a charm.
So if anyone is wondering- do NOT connect the yellowbox to the VSS pin on the ECU. Just connect it down by the VSS itself, on the transmission.
Longer gears are nice- the 3.76:1 ratio vs the 4.27:1 is about 12% longer
Old 11-17-07, 03:51 AM
  #49
97-SC300
97-SC300's Avatar
awsome glad to head everything was ok. BTW where did you mount the yellowbox? how did you run the wires inside?
Old 11-17-07, 06:14 AM
  #50
Blizzy
Blizzy's Avatar
How fast are you going before you have to shift into overdrive?
These gears have to make your car a high speed assassin.
Congrats on the speedo error fix. I will be reaccessing this thread when I swap the R154 into my SC.
Old 11-17-07, 06:43 AM
  #51
ScottURnot
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
Glad to see you got the yellow box to work, I am sure I am going to need this with my swap.
Old 11-17-07, 09:09 AM
  #52
Blk97SC300
Blk97SC300's Avatar
I drilled a tiny hole right next to the speed sensor and ran two wires inside the cabin. I already had power and ground tapped, so I just needed to connect the white and grey wires (from the yellow box) to the speed sensor wire. Then I put silicone duct tape over the hole. I didnt feel like running it thru the engine bay or thru the shifter hole- so i made my own little hole
I just left the yellowbox to the side of the ecu's big black plastic cover. Pretty much where all my other crap is stuffed haha (MAP ECU, greddy gauge control unit thing, yellow box).
Blizzy- Yea, with a 67mm turbo and lots of boost- I definately wana be a high speed deamon. High speed assasin0 I like that
Scott- thanks. It's a really cool little unit, and it's got a 10 yr warranty too I think? For about $100, its not too bad. It could adjust + / - 28%. It does its job, so i'm happy. Good luck with your car- it's going thru some major mods
Old 01-10-08, 09:45 AM
  #53
lexforlife
lexforlife's Avatar
I installed a rear end (the entire pumpkin) from a 1997 automatic supra TT. The ONLY thing that needed to be swapped over from my stock sc300 pumpkin to the auto supra tt pumpkin was the yoke.
A 35mm deep socket is needed. It was a major PITA finding this, but a local Kragen had exactly what I needed. It only took a couple hours to swap the pumpkins. Very simple, straight forward, nothing too difficult. A friend helped me, cuz the rear diff is pretty damn heavy. It's definately easier with an extra pair of hands.
The car handles better, launches better, and overall feels a lot more solid. Oh, and it leave two nice 275mm wide rubber marks too if I feel like doing something crazy
Not only do I now have a torsen limited slip diff installed, I'm also using the 3.76 gears. I couldn't stand the 4.27 gear ratio that came with my automatic sc300 rear end. This will increase my top speed from about 160mph (old gears) to a hair over 180mph (new gears).. not that I'd ever be doing anything like that anyway
LSD and longer gears are nice- it'll be definately to my advantage with a 67mm turbo. I'll be in each gear longer, and even be in the powerband longer. It's actually noticeably faster at higher speeds now
To clear things up, the rear end from an auto TT supra IS a direct bolt on "upgrade/mod" for a sc300- as long as the yokes are swapped.
-Allen
allen
did you have to swap out the axles too or just the diff
Old 01-10-08, 09:49 AM
  #54
97-SC300
97-SC300's Avatar
you can keep teh sc axles no need to swap
Old 01-10-08, 12:06 PM
  #55
crx378
crx378's Avatar
i am so close to installing my lsd pumpkin, stupid daily driver. soon though real soon.
Old 01-10-08, 04:57 PM
  #56
Blk97SC300
Blk97SC300's Avatar
it only takes a couple hours.
lexforlife- stock SC axles fit just fine
Old 01-10-08, 05:34 PM
  #57
forcefed86
forcefed86's Avatar
Any pictures of the rear end install? I've got a very similar setup with a 61mm turbo. I'm looking into buying the 3.76 gear swap as well.
Nice car! I think you've got some serious power that could be free'd up in that tune of yours though. Something doesn't sound right with those numbers. I'm making around the same power w my setup. Almost exactly like yours. Even the same exhaust but no exhaust dump.
Recently dynoed at ATS racing 420 rwhp/404 torque on 17 pounds and pump gas. At 21 pounds it put down 483 rwhp/435 torque with a mix of pump/VP110 octane.
This is with a crappy vpc gcc setup. And an automatic Boost logic tranny w/ a loose 3300 converter.
I'll trade ya...?
Old 12-16-12, 04:42 PM
  #58
Bksc718
Bksc718's Avatar
love your car bro
Old 04-08-15, 07:53 AM
  #59
megamax
megamax's Avatar
bumppers!!
Old 11-03-16, 08:25 AM
  #60
BigGreen
BigGreen's Avatar
has anyone used a marlin crawler vss to fix the speedometer issue after installing auto tt diff into sc300 with r154 tranny?
Quick Reply: Auto Supra TT Diff Installed (LSD and 3.76 gears)
