Auto Supra TT Diff Installed (LSD and 3.76 gears)
Old 10-16-07, 06:02 PM
Blizzy
Blizzy's Avatar
Originally Posted by TTSC3
4.76, you meant 3.76, right? Also, mating the 6spd getrag tranny to the Auto TT diff isn't an issue I assume? I hope not, lol, because that's the combo I bought!
That is my bad. I meant 3.1 and 3.76 for the 6MT and AutoTT respectively.
A getrag will shred off the line with a 3.76 rear end, but a 3.1 rear end would be a much more sensible choice for street manners. Perhaps the ultimate rear end for the Getrag would be the 3.2 JDM gears, since you would have the best of both worlds.
Nevertheless, a 3.76 geared 6MT is not really suggested.
If you want to keep the SC's axles, I would suggest the 3.26 rear from the 5AT 98-00 SC400 and GS400. Swapping the LSD unit from the Auto TT diff itself onto the 5AT's more appropriate ring gear ratio and into the pumpkin with fewer fitment constraints would be logical.
Old 10-16-07, 06:36 PM
BLovesc
BLovesc's Avatar
Sounds good have your driven on a 2way in a sc before? Feel any difference?
Old 10-16-07, 06:39 PM
Blk97SC300
Blk97SC300's Avatar
I just took a look at my spare W58 transmission.. 97-SC300 was right. thanks for the prompt reply
The speed sensor for the sc300 IS, in fact, a 3 wire sensor. I e-mailed the yellow box guys, and told them to send me a 3 wire (instead of a 2wire) yellow box.
I'll keep this thread alive with any/all updates.
FYI:
6spd supra TT = 3.133 (all had LSD)
auto supra TT = 3.76 (93-96 had LSD, 97-98 LSD was an option)
5spd sc300 = 4.08
auto sc300 = 4.27
Old 10-16-07, 08:38 PM
96sc3
96sc3's Avatar
let us know how it goes. btw, how off is the speedo now?
Old 10-17-07, 12:03 AM
Blk97SC300
Blk97SC300's Avatar
it's off by about 12%.
When the speedo says 50mph, I'm actually travelling 56mph.
When it says 70mph, i'm actually going 78mph. etc..
I ordered the Yellow Box. it should be here within 10 days, supposedly (coming from australia). They're gona send me the 3 wire unit, so i'm hoping itll work just fine.
well, on the positive side (for the time being), for evey 112 miles I drive, the odometer only counts 100 miles, right?
Old 10-17-07, 07:36 PM
96sc3
96sc3's Avatar
That is true,
Leaving the speedo alone might be a good idea
Old 10-18-07, 08:16 AM
97-SC300
97-SC300's Avatar
yeah just dont forget about changing the oil before it hits 3,000 lol.
Old 10-18-07, 08:27 AM
Dx3
Dx3's Avatar
Originally Posted by 97-SC300
i actually just loked a the wiring diagram for the 97 sc300 speed sensor and its a 3 wire sensor.
So it pre-97 a 2-wire?
What color are the stock wires you use?
Jonny
Old 10-18-07, 08:30 AM
97-SC300
97-SC300's Avatar
yellow=power
red=ground
blue w/red stripe= signal
Old 10-18-07, 10:03 AM
Gunnar
Gunnar's Avatar
160 MPH with 4.27's? That doesn't seem right unless you're revving higher, since the 4.08's run out of gear at 150ish?
Old 10-18-07, 10:34 AM
Blk97SC300
Blk97SC300's Avatar
cutoff is about 6,800rpm.
I got an e-mail from the yellow box company- I should receive the part within 2 weeks.
Old 10-18-07, 10:35 AM
Blk97SC300
Blk97SC300's Avatar
yellow=power
red=ground
thanks for the info- I was kinda curious about that
Old 10-24-07, 08:12 AM
Blk97SC300
Blk97SC300's Avatar
Hey guys, update time. Australia FTW!
They shipped out the package on Thursday, and it arrived on Tuesday- shipping was only $10
I think I'll install this thing sometime tommorrow. Should I install it at the speed sensor on the tranny, or at the actual ECU?
yellow=power
red=ground
I know the signal wire could be found on the ECU.. does anyone know which pins on the ECU the yellow and red wire are at- or could I simply use any power and ground?
Old 10-24-07, 11:35 AM
MDeezy
MDeezy's Avatar
i would say wire it to a power and ground wire on the ecu. So once the ecu gets power same with the speed sensor.
Old 10-25-07, 03:12 AM
2jznat
2jznat's Avatar
well how did it go?
Quick Reply: Auto Supra TT Diff Installed (LSD and 3.76 gears)
