Bearings?
Super Moderator
Location: Sideways on the Yellow Brick Road! < Thats KS!
I special ordered an idler pulley bearing from Fastenal. You should be able to press the bearings out and match them up at a bearing supply shop. I measured mine out and then ordered a off the shelf one, took a couple days to come in.
2RS 6203 should be the part number. Most bearing houses get their bearings from China believe it or not. They run ~$5.50 per. Federal Mogul make their own, and they run ~15.00 per. All the same to a point.
Eric
Eric
