1jz/2jz Oil Feed & Drain Question
What are you running for feed and drain size on your single turbo setup and did you utilize the factory drain flange on the pan?
I ask because I am currently at -4 feed / -8 drain into pan but isn't the pan's return hole smaller than -8, did you modify/enlarge your return at all at the pan? I am thinking about going to -10 but if the return on the pan is only so big, it's not going to make a differance.
I will get some pics of what my setup looks like tomorrow afternoon.
