Name this tranny: W58 or R154?
The bellhousing for an r154 is different as well, it has holes so you can unbolt the clutch pressure plate. The slave cylinder is different, and if you took a pic of the other side, you could tell by the speed sensor.
I figured it out about an hour after my original post.
It's hard to tell at first, but after about 2 hours of research, the differences became glaring. The position of the shifter outlet was what originally threw me off. But there are like 4 shifter positions for W58s.
But the dead ringer was the shape of the rear half of the transmission. The R154 has a more compressed section with ribs, the W58 is larger and smooth.
Thanks!
Thanks!
thanks drewgo
just to confirm this a picture of the old clutch in the car.
to me looks like a 2jzge non turbo/7mge non turbo push type clutch. and flywheel needed for the pressure plate to mount to would be for the same application 2jzge/7mge.
