Excessive oil consumption???
Old 08-04-07, 11:10 PM
Ac93sc
Ac93sc's Avatar
Default Excessive oil consumption???
Wander is this normal or .........and does anyone expriencing it?
i change my car engine oil every 3k miles, but when it's around 2.5k the engine light in the dash would go on, when i check i found out it's missing 1 quart of oil. My mechanic checked the car and find no oil leak. this is the second time i changed the engine oil after i bough the car and this happen twice too. So i google it and found this in consumerguideauto.com.
Oil consumption: Excessive oil consumption caused by sludge buildup on the cylinder heads. Company is extending warranty. (1993-00)
Old 08-05-07, 06:35 AM
sc250tt
sc250tt's Avatar
My sc3 use to use alot of oil until i used seafoam and used the right oil .try seafoamong the engine it will help alot
Old 08-05-07, 06:53 AM
Lexmex
Super Moderator
Lexmex's Avatar
What kind of oil are you using?
Old 08-05-07, 08:39 AM
simann
simann's Avatar
Mine is consuming oil around the 3K mile range after a fresh oil change too. I have 165K miles and the motor still runs strong, no hint of lost compression.
I think its more due to valvetrain wear than anything else. More often than not the valve stem oil seals just get old, brittle, and leak oil into the combustion chamber, there you will see the lost oil.
With a stock exhaust system with 3 old clogged catalytic converters you will probably not see any oil smoke until its far too late, but for that amount of oil to be burning you would have to have a piston ring failure or more.
All in all, its normal wear and tear if you will. Things wear out and need replacement.
I am just waiting for my motor to kind of......"die of old age" so I will have a reason to drop in a nice GTE swap. But until then the car right now as it stands is all I need for daily use.
-Jonathan
Old 08-05-07, 04:56 PM
Ac93sc
Ac93sc's Avatar
my car is around 135k and for the oil i use 5W30.
i heard about the seafoam but i don't think i will have a good chance to do it since CA law is strict. but how many oil are you guy experiencing excessive consumption?
Old 08-05-07, 05:06 PM
vwynn
vwynn's Avatar
cali law is strict about seafoam?? yea right.. lol ive been seafoaming my car on the street of my drive way.. and i have a cop neighbor haha..
Old 08-05-07, 06:03 PM
Ac93sc
Ac93sc's Avatar
lucky you................try it in the S.F area...hope you don't get a ticket. my fd got a warning from a cop doing something similiar.
shiny250
11-30-13 06:55 PM
amerquresh
05-11-12 06:39 PM
99rx
RX - 1st Gen (1999-2003)
20
03-13-10 01:00 AM
tabraha
11-14-04 10:15 PM
LEXISM
Performance
06-09-04 10:57 PM
Quick Reply: Excessive oil consumption???
