oil filter location SC300?
Old 07-10-07, 12:41 PM
SC300 J
SC300 J's Avatar
Default oil filter location SC300?
Hey guys trying to change my oil on the sc300 and can't seem to locate where the oil filter is underneath?
Little help for a newbie much appreciated, thanks
DryBlaze
DryBlaze's Avatar
Under the intake manifold runners.
Old 07-10-07, 01:21 PM
na4now
na4now's Avatar
If you cant find it on your own, you might not want to change it yourself. It can get messy.
Old 07-10-07, 09:20 PM
AdvanSC300
AdvanSC300's Avatar
Dryblaze is correct,it is located on side of your engine just below the intake,I change my filter from the top,there is enough room to reach it from the top,after spray some brake cleaner around the filter are and then rinse it off with a hose,I recommend to use a Toyota filter to reduce the chance of the filter gasket leak as the aftermarket ones are known to do...
Old 07-10-07, 09:58 PM
nismo2trd
nismo2trd's Avatar
true. pay someone to do it if u cant do it.
my 2 cent if u cant find the oil filter dont get under the car.
Old 07-10-07, 11:04 PM
FormosaSC
FormosaSC's Avatar
who here didnt start learning how to fix their own car from changing their own oil? let the guy learn, get his hands dirty... a word or warning tho... once you start doing it yourself... it can get addictive good luck.
Oh also remember to buy the ring from lexus, youll need that.
Old 07-11-07, 12:56 PM
DryBlaze
DryBlaze's Avatar
An oil filter is not hard at all and is not messy at all.....
Just drain your oil (hopefully you knew you had to do that before removing oil filter)
Then stick you arm under the intake runners and unscrew. If you cna reach it then go under the car and do it.
Its very very simple.
kimsey
12-01-15 03:00 PM
jimbosr1
09-06-13 06:34 PM
Huynh9999
RX - 3rd Gen (2010-2015)
03-02-13 09:15 PM
ctls
08-27-07 02:18 PM
ntran18
Maintenance
23
11-30-04 11:20 AM
Quick Reply: oil filter location SC300?
