Crank pulley debate
Old 06-17-07, 07:10 AM
Jinx2006
Jinx2006's Avatar
Default Crank pulley debate
So I have searched on this forum and others, but I am getting different opinions. Has anyone ran Unorthodox racing's crank pulley for an extended period of time, and if so, any problems/praises? I am debating on purchasing one in my "pursuit of unsqueakiness", a problem which is in another thread.
Old 06-17-07, 07:43 AM
Jinx2006
Jinx2006's Avatar
Amazing what you can find with a few clicks! Here's what Unorthodox Racing says about this issue......
"People are getting their crank pulleys confused with the harmonic dampers found on some V6 / V8 engines. "Harmonic Balancer" is a term used loosely in the automotive industry. Technically, this type of device does not exist. The "balancer" part comes from engines that are externally balanced and have a counterweight cast into the damper, hence the merging of the two terms. None of the applications we offer use a counterweight as part of the pulley, as these engines are all internally balanced.
The pulleys on most of the new import and smaller domestic engines have an elastomer (rubber ring) incorporated into the pulley that makes them look similar to a harmonic damper. The elastomer in the OEM pulley serves as an isolator, which is there to suppress natural vibration and noise from the engine itself, the A/C compressor, P/S pump, and alternator. This is what the manufacturers call NVH (Noise Vibration & Harshness) when referring to noticeable noise and vibration in the passenger compartment. It is important to note in these applications, the elastomer is inadequate in size and durability to act as an effective torsional damper. If you look at the pulleys on some imports there is no rubber to be found at all. We have samples of these, mostly from Acura/Honda, the Nissan Altima, 1.8L Eclipse, 2.3L Fords, Chrysler 2.2L's, and 1.8L VW's, to mention a few. This is not to say with our pulleys you will hear a ton of noise or feel more vibration from your engine compartment. Most owners who have installed our pulleys notice the engine actually feels smoother. This is result of replacing the heavy crank pulley with our crank pulley. NVH is variable and unique to every car. NVH will increase with the installation of an aftermarket intake and/or exhaust, for example. Think of OEM intake systems in newer cars, they use baffles and resonators in the intake to quiet all the intake noise. Aftermarket intakes eliminate these resonators and create dramatic increases in engine noise from the throttle opening and closing. So to most tuners, certain types of NVH can make the driving experience more enjoyable.
The purpose of a traditional harmonic damper is to protect against crank failure from torsional movement. This is not necessary in most modern engines because of the many advances in engine design and materials. Factors such as stroke length, displacement, inline, V configurations, piston dwell time, piston pin off-set, power output, etc., do determine when and how these harmonics and torsional movements occur.
Again, there is a lot of internet hearsay about crank pulleys. When engine problems occur, too often people are quick to blame the pulley first, rather than taking the time to look logically into why there was a problem. We hope that after reading this you will understand the crank pulleys better."
Whatcha think?
Old 06-17-07, 08:24 AM
Lexmex
Super Moderator
Lexmex's Avatar
I run a lightweight crankshaft pulley from Underdog on my RX300 and have had no problems in almost than 1.5 years of use. About the only import thing is to make sure the belts are clean to get better effectiveness.
You mentioned Unorthodox. My cousin has a 1995 VW Golf VR6 and I bought him some UR pulleys a while back. No issues. You can feel the hard pull almost immediately, though the feeling is less so as you hit about 3rd. They took about a week's worth of driving, before the full potential was realized, but they took a good .15 off of his 1/4 mile time by my calculations.
Old 06-17-07, 09:46 AM
Jinx2006
Jinx2006's Avatar
That's good to hear! So do those cars have a torsion/dampener in the crank pulley? That's what SC300 owners are concerned about, because the UR pulley doesn't have it. i'll see if more people can give me opinions before I decide for sure, but I'm sold so far.
Old 06-17-07, 10:16 AM
got_trd
got_trd's Avatar
about 2 years or more on my unorthodox racing crank pulley when i had the 1jz in and no problems whatsoever with the abuse i gave that motor...
Old 06-17-07, 01:26 PM
$C300
$C300's Avatar
iv had my Underdrive pulley for almost 4k miles, no prob here.
Old 06-17-07, 03:00 PM
Jinx2006
Jinx2006's Avatar
Nice,nice. Well, ladies and gents, I'm sold.I'l have them in a week or two Another answer, another thread we can close. Thanx a mill guys!
Old 06-17-07, 03:56 PM
bmsport
bmsport's Avatar
I run a ATI harmonic dampener, originally i ran a unorthodox unit and just happened to spin a bearing, but i also had other parts and problems that could have contributed to that unfortunate event. The new ATI unit designed after the stock dampener and is only slightly more money than OEM. However, the ATI unit is far superior as the rubber dampening bushings are encased inside the unit preventing oil and road debree from degrading them. Actually, the Titan Motorsports crank pulley is an ATI with a sticker on it jacked up $100. I am 100% sold on the ATI unit. Just my .02
Old 06-20-07, 11:39 AM
Bean
Bean's Avatar
I guess all the info out there about 2jz motors dying prematurely from undamped pullies is just going to go unheeded. Oh well. Have fun with that.
Old 06-20-07, 11:49 AM
Pearlpower
Pearlpower's Avatar
Ran one on my Tundra for a great many miles. Never an issue. Know many people that run them as well and again-not one issue -ever.
Old 06-20-07, 01:42 PM
ISC400
ISC400's Avatar
Good info
Old 06-20-07, 05:06 PM
5spdSC300
5spdSC300's Avatar
It amazes me how so many people over look this information. Why would yota design our crank pulleys with dampeners if a non dampened pulley could be used with equal or better results? I would imagine a simple non dampened pulley could be mass produced for much less than a dampened one.
One thing i would like to point out about the quote from UR's website...Do you guys honestly think they would tell you the truth if they knew there pulleys caused problems down the road? This is there product and of course they are going to support it as much as they can and "debunk" these hearsays. Do they have any real r&d data of there own products? If what UR says is true, why is it required by the NHRA to have a dampened crank pulley to legally compete even in the sport compact class?
Old 06-20-07, 06:01 PM
Pearlpower
Pearlpower's Avatar
The exact opposite can he said as well, it all depends on what one's opinion on the item is.
Some will run it, others will not. Nobody is going to change the world here.
Old 06-20-07, 07:22 PM
Bean
Bean's Avatar
Its not an opinion though. Its in the motor's design specs. Thats like pulling the CPU cooler off the CPU and expecting it to last forever.
Some of the new chips run pretty cool; but they will eventually wear prematurely from excess heat fluctuations.
Old 06-20-07, 07:38 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
https://www.clublexus.com/forums/sho...=288753&page=2
here's another thread about the same exact thing we are in the middle of still...
is it worth the 5 hp to potentially damage your motor? seriously... there are lots more hp options that are not potentially dangerous...
Quick Reply: Crank pulley debate
