1jz idling problem, please help!!!
Old 05-24-07, 01:49 PM
D1GP
D1GP's Avatar
Default 1jz idling problem, please help!!!
This happened recently, where after going over 50~+mph, and when coming to a complete stop at a red light or stop sign, the car idles really low and having a hard time to stay alive. I got a battery voltage meter and it shows that when driving, it is at 14.5V, and once I put the gear in neutral, rolling or stop, the voltage drops dramatically to below 12V and eventually the car stalls. Once I restart the car, the voltage is back up to 12~13 and gradually moves up to 14.5V.
Anyone know the problem here? Thanks in advance. much help will be apprecitated.
Old 05-24-07, 03:38 PM
Answer300
Answer300's Avatar
you may could use a voltage stabilizer. is you battery relocated?
Old 05-25-07, 11:51 AM
D1GP
D1GP's Avatar
I got the buddy club condenser, doesn't seem like it is helping.
Old 06-12-07, 11:25 AM
D1GP
D1GP's Avatar
I rencently replaced my Optima batter with another Red Top and it doesn't drop below 12V anymore, but the Voltage still drops from 14.8 to 12V at idle
anyone else have diff. remedies?
Old 06-12-07, 01:26 PM
jefferino
jefferino's Avatar
I have a BC condenser also and mine never has any problems and has helped. Not sure why yours would do that?? I'd check your grounds and such.
Old 06-12-07, 02:11 PM
TheMole
TheMole's Avatar
How about your alternator? Does the battery light come on? If not these then maybe checkout the idle air control valve or throttle position sensor.
Old 06-12-07, 02:50 PM
D1GP
D1GP's Avatar
I have tested my altenator by disconnecting the ground to the battery while the car is on and it is fine.
Even thought the voltage drops to 12V, but it slowly climbs back up to 13.5V.
Its weird...
my battery is located in the trunk, and I have 1 ground point there and for the engine bay, I have the buddy club condenser in which I got 3 grounding points.
where can I get the IACV gasket? so I can remove it and clean it out
Old 06-13-07, 12:00 AM
JohnEd
JohnEd's Avatar
Default weird
D1,
It is a weird problem. The real puzzler is the voltage droping and then rising. That is only a mystery if theengine rpm stays the same. Your problem sounds like an intermittant one, although it is predictable. I liked your test where you disconnected the bat while the eng was running. You said the voltage still droped to less than 12 at idle and then rose to ?? after a few seconds while the rpm stayed the same. The engine kept running after the bat was disconnected and it should but the voltage should not have dipped like you said. Got a buddy with the same parts? Swap the alternators. AND OH MY GOD.....you are describing a loose alternator belt symptom. Check that first and it has to be TIGHT.
Good luck
John
Old 06-13-07, 01:29 AM
TheMole
TheMole's Avatar
A couple of days before, I was driving at night and all my lights started to dim when I signaled. My battery light soon came on so I turned off the radio and it went away. My battery is a few months old so it could not have been that. I did some research and found that it was the alternator. The mechanic tested it with a volt meter and it was around 14 and he said the norm at idle is supposed to be in the mid 20s. I had it replaced because I did not want to be stranded somewhere.
As for the iacv I can't find the gasket, but it should probably be the same as the 2jzgte one.
Old 06-13-07, 12:55 PM
D1GP
D1GP's Avatar
Originally Posted by JohnEd
D1,
Good luck
John
i actually have a set of unorthodox pullies, and the serpentine belt is really tight.
When the voltage drops really low, so does the idle, but sometimes will climb back up, other times, i had to tap a little on the gas to keep the RPM up. So the RPM fluctuates with the batter voltage. I will check my idle speed control valve. Dunno if thats the prob, but will give it a try.
If I don't drive the car hard, it usually doesn't have this drop in the voltage problem.
anyone else got comment, please post on here to help solve this problem. Thanks
Old 06-26-07, 03:32 PM
D1GP
D1GP's Avatar
anyone else got input on this problem?
Old 06-26-07, 06:48 PM
TheMole
TheMole's Avatar
Not sure if this helps, but right before I sold my auto Accord something similar happened. I would be going at a bit over 40mph and when I brake hard to a stop the idle would drop low and it felt like it was going to die. Not sure if I fixed it, but I cleaned out the iacv, replaced pcv valve, and the battery because it failed a load test when I went to get an oil change. I tested it for about a week in the same situation before I sold it and I could not reproduce the low idle.
Edit: O yea forgot to mention I replaced the distributor cap and rotor during that time as well.
Old 06-27-07, 11:43 AM
TO_SC300
TO_SC300's Avatar
I had a similar problem with the engine idling rough and would just die on my SC300. It ended up being an oil leak in the head gasket, the oil was pooling in the plug holes, and the oil was running up the plug wire. The current would then go across the oil to the head of the engine instead of thru the spark plug so it would not fire. Odd one, I know, but I thought I'd share it because it took me a while to try tracking it down, I eventually gave up and took it to lexus.
bowen.chau
RX - 1st Gen (1999-2003)
16
02-15-11 08:08 AM
Murvilboy
SC- 1st Gen (1992-2000)
05-23-10 07:37 PM
sleeper408
10-30-09 08:17 PM
kasper634
11-04-02 12:26 PM
Quick Reply: 1jz idling problem, please help!!!
