6spd Getrag in SC with 2JZ-GTE?
I just have a quick question for some of you that are already running the setup in your GTE powered SC. Besides a different clutch and driveshaft, is there anything else you need to do to make this swap work? Is there someone online that sells a driveshaft for this conversion? Any changes need to be made to the rear end, or will the stock SC one work? Basically, I'm just looking for the rundown of what all needs to be done, as far as parts are concerned. That way I can order everything I need and have it on hand, ready to go! Thanks ahead of time.
george this has been covered many times, but, here is what you also need.
crossmember support, different rearend (tt or gs400)or output flange from a 6 speed rearend. tt 6 speed slave cyl, misc small obvious items and thats about it from what you said, if you have questions let me know, i just did the swap recently.
ben
ben
ben
ben
Ok, I've already got the swap done, but I'm using the W58. I just wanted to swap to the 6spd because the W58 is just terrible. Anyway, do I need a 6spd rearend, or will an auto work? I'm pretty much ready to just buy what I need and get the swap done! Thanks for the replies.
