soarer fuel setup
soarer fuel setup
I have 2 walbro pumps. Im going to Y them into a single line to go forward to rail. Do i use the stock return line? Do i have to remove and cap the original feed line or just leave it as it is no longer connected?
thanks in advance.
thanks in advance.
re
do as you please.
if youa re using aftermarket rail, then i'd rip off the useless stock feed line, blocking off the port for the tank it came from(unless u're drilling it out and welding in new fitting there)
and i'm using the stock return for now. . .similar set-up i'm guessing
ScSlide
Performance & Maintenance
11-07-09 07:14 PM
