Vacuum tubing question
Old 05-10-07, 11:48 AM
T0ked
T0ked's Avatar
Default Vacuum tubing question
What do people use to replace the factory tubing? I was fiddling with one under the hood and it ended up ripping... a bit too easily for my tastes. After 14 years, I think it might be time to replace some of them. What is a good replacement for the tubing in our cars? Do people recommend the generic silicon tubing all over fleabay? I don't want any crazy colors and such just something that is a good suitable replacement that's OEM quality or better. Thanks.
Old 05-10-07, 11:58 AM
Rising_Sun
Rising_Sun's Avatar
Silicone hoses are the way to go. Most companies will produce them in gloss black as well as those neon colors. There is nothing more frustrating than hunting down dried and cracked vacuum lines.
Old 05-11-13, 08:36 PM
MyLexs400
MyLexs400's Avatar
Anybody have a rough estimate of how much of each diameter hose is needed to do a conversion to silicone hoses?
Old 05-12-13, 01:11 PM
MooJohn
MooJohn's Avatar
I took a piece of the stock tubing into AutoZone and matched it with their vac hose and then bought 15 ft. If the original can go 20+ years, I'm sure it will be fine to use it again for another 20+ years.
93sc400nm
08-01-17 09:31 PM
akobari
01-23-17 05:52 AM
triacon
11-24-14 12:33 PM
clintbw
03-16-14 04:36 PM
IS_Sunny
06-10-08 12:07 PM
Quick Reply: Vacuum tubing question
