Weird Problem, Any others?
Old 05-10-07, 06:06 AM
JDMmuscle
JDMmuscle's Avatar
Default Weird Problem, Any others?
Ok, so i was driving to work this morning...
and my car keep like shuting off while i was driving, then it would kick it self back on, transmtion was engaging and disengaging , When ever i would go to put the pass' side window down the radio would turn off, the automatic stearing wheel set thing is REALLY slow to retract and extend, and to top it off, when its in park, the idol bounce's back and forth from just below 1000rpms to around 3k!!!! it will rev up then drop, rev up then drop, and so on so on, Checked the fuse's that i thought would mess things up, everything is fine,
Any ideas? please help
Old 05-10-07, 06:08 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
This is an engine question.
Moved.
Old 05-10-07, 06:11 AM
sc250tt
sc250tt's Avatar
did you ever raise the front or the car back up? you probably destroyed the wires under the cowl on the driver side
Old 05-10-07, 06:15 AM
JDMmuscle
JDMmuscle's Avatar
Oh ****.... you might be on to somthing there... **** me, another rewireing job damn it
me and my VIP wanabe ***
Old 05-10-07, 08:57 AM
sc250tt
sc250tt's Avatar
lol thats why my sc's are not lowered too much i had bad experiences with buying tires every month but if that not the problem cheack the body grounds
Old 05-11-07, 09:45 PM
JDMmuscle
JDMmuscle's Avatar
ok so cut all the ****ed up wires.... Repliced everything, redid everything, checked, double checked, triple checked... checked my fuse's everything
Engine STILL idols at 3k, but stays firm there, no reving / dereving, Now windsheild wipers WONT turn off... and it is running soooo rich that it is literally dripping drops of gas out of my tail pipe...
Wtf is going on, please help
Old 05-12-07, 10:07 AM
sc250tt
sc250tt's Avatar
try resetting the ecu
Old 05-12-07, 11:45 AM
JDMmuscle
JDMmuscle's Avatar
How would you do that?
Old 05-12-07, 12:09 PM
mkorsu
Zombie Slayer
mkorsu's Avatar
Disconnect negative battery cable for 15 minutes.
Och
09-23-12 09:08 AM
Benbendx
01-19-11 04:24 PM
1991LexMan
15
08-25-09 01:46 PM
tcd300
20
10-03-08 11:15 PM
ceboyd
07-29-03 06:07 PM
Quick Reply: Weird Problem, Any others?
