What kind of motor is this?
Old 05-09-07, 12:13 AM
contentryd
contentryd's Avatar
Default What kind of motor is this?
I had someone say it is a 1jz, but it don't look like it to me...
couple more pics to determine:
btw, I just got this car..a '98 SC300
I also have a few questions:
1. My driver side front and rear turn signal flashes quicker than my right side...Today, the left front signal went dead. My right headlight assembly has moisture inside, then I fixed the loose harness. My left rear still blinks fast, though my front left doesn't work. Anybody know the problem?
2. I had the hood repaired, when I tried to use washer fluid to get bugs out my windshield..Nothing came squirting out...I checked that the hose wasn't connected. I don't know where to connect it...Does anybody know?
Thanks!
Old 05-09-07, 12:28 AM
habitat
habitat's Avatar
That is a 2jz-GE.
Old 05-09-07, 12:29 AM
Baker
Baker's Avatar
Looks like a IS300 engine to me. Headers and all.
Old 05-09-07, 12:31 AM
habitat
habitat's Avatar
The timing belt cover does look like one from an IS300 2jz
Old 05-09-07, 12:34 AM
Baker
Baker's Avatar
Originally Posted by habitat
Which is a 2jz-ge... I cant tell any difference from the headers.
You are correct 2J.
Old 05-09-07, 12:52 AM
reamemiya
reamemiya's Avatar
Because it's the same motor from an is300. For Sc's the vvti 2jz-ge came in the 98 and up.
Old 05-09-07, 12:57 AM
contentryd
contentryd's Avatar
so the car has a supra motor swap? capable of boosting?
Old 05-09-07, 01:09 AM
ElitistK
ElitistK's Avatar
if you look at it closely, there is a 2jzge sticker on the cam cover.
it's the supra non-turbo motor. you could boost it, but by 300 rwhp you need a new headgasket to lower compression. by 450rwhp it is recommended to get your bottom end built, or swap to the gte bottom end. I would just get it built since you need to open up your motor to change the headgasket anyway.
edit: w0000t 700th post on CL.
Old 05-09-07, 01:11 AM
na4now
na4now's Avatar
Stock engine. Yes you can boost it.
Old 05-09-07, 01:26 AM
FiSta
FiSta's Avatar
for the fast blinker problem...just get a new front bulb and it should go away
and i believe the washer hose runs along under driver side fender
Old 05-09-07, 02:48 AM
contentryd
contentryd's Avatar
ahhh i didn't notice the 2jz sticker on the cam cover, thanks lol
what bulb type should i get..and do i change the front or rear? or both?
Old 05-09-07, 03:21 AM
PsiQo1
PsiQo1's Avatar
its the kind that needs a washing ---but seriously its a 2jzge --- also seriously i just detailed my engine and its well worth it.. you will feel better about driving your car after the engine shines even tho you dont see it
Old 05-09-07, 06:28 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
NO!!!!
The Supra, the SC, AND the IS all used the 2JZ-GE engine as their base.
ITS NOT A SUPRA MOTOR SWAP!!!!!
Old 05-09-07, 11:40 AM
contentryd
contentryd's Avatar
Originally Posted by mkorsu
NO!!!!
im still a noob at this lol
Old 05-09-07, 11:50 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
It's cool. I was having a bad morning this morning in work.
Quick Reply: What kind of motor is this?
