Will an LS400 rear bolt up to an SC?
From what I've seen the LS400 has the same rear end gearing as an SC400. So will it it bolt up? Would like to know before buying.
I just figured I should follow this up. The LS diffy has two bolts in the rear whereas the SC has three. It also has only one bolt, RHS, mounting it to the undercarriage that's closer to the axle as compared to SC's two bolts. Thank you, I didn't get it on that note.
Thanks for the promo. Dot's a cool name too, and one I could almost see being used in real life
Matt300ZXT
Suspension and Brakes
07-12-10 09:17 PM
