What model is my motor from?
Hey forum dwellers, I have a quick question.
I purchased a SC300 w/ 1JZGTE. Here's the question, how do I confirm exactly what car (chaser, supra(not 2J, I know better), soarer, etc..) this motor came out of?
Also, how do I know the motor code (JZZ30,JZX110,etc...)?
I'd like to upgrade a few things and would like to make sure I'm buying the correct things for the correct motor or setup.
Here's a pic of under my hood:
[IMG][/IMG]
[IMG][/IMG]
from looking at it its you have a supra engine .no clutch fan and some hoses on the turbo mani is shorter on yours.the soarer engine sets have clutch fans .if you dont have a clutch fan its not a soarer engine
i would think it would be fairly safe to assume its a soarer motorset. Cant you ask the builder? Also on that fan it simply looks like the fan was removed ( probably for electric fans) the bolts and nuts on the pulley look just like mine when the fan was off.
Anyway, any 1J part you are buying would pretty much be the same ( regardless in what it is ) what parts are you looking to get that you need to know exactally what car the 1J came from?
The unless the wire harness was replaced, the supra 1JZ has a second pressure sensor and harness by the igniter. The MKIII supra came stock with a WORKING boost gauge in the dash. It really doesn't matter which 1JZ motor you have, the water pump is now correct and oil pan. You could even be using a soarer ECU or Chaser ECU. All 1JZ performance parts are interchangable anyways. Hard pipes for the intercooler and a larger exhaust will really wake up your motor.
